Z06/Z07 or Carbon to ZR1
I would appreciate perspective from anyone that has moved from a 2011-2013 Z07 or 2011 Carbon HC/CAI to a stock ZR1. The RWHP should be very close and I am curious if the added torque in the ZR1 made any difference, was the ZR1 faster, were you disappointed? I am trying to get feedback from those with the Z07 or Carbon because they have all of the ZR1 components (except the LS9, of course) thanks.
Too-Fast (10-20-2018)
Love my ‘11 Z07! Having driven a buddy’s ‘10 ZR1 a few times, I thought that the ZR1 had a little stronger low rpm torque, but definitely felt heavier (almost like my CTS-V) in normal driving.
Too-Fast (10-21-2018)
The ls9 has a tiny bit of a supercharger lag, even though it's a root blower, maybe it's the low compression of the ls9 motor that makes it feel like that,, I'm not sure, I just remember my ls7 felt instantaneous with throttle response. Power wise, the zr1 feels better in the higher gears, it's odd because even from a low rpm in sixth gear it will still surprise you how much power it has, that's where I felt my Z06 lacked in comparison
I carefully considered the two options, and ultimately decided the ZR1 wasn't for me (I come from the "light is right" camp), same reason why I don't dig the C7 Z. I also didn't see the value in the addtional $10K to $15K over the Carbon I purchased. Now that I've educated myself a bit on the differences (LS9 block is made of stroger alloy, the performance trans ratios, etc.) that delta is a little clearer, but it would not change my decision.
This doesn't really answer your specific question, as I have not driven a ZR1.
You have an IO Z07, tied for best overall with an IO ZR1 in my book. I would not let your car go for a ZR1 unless it is an IO car. Also, you would want to mod the ZR1 a little to outrun your current car. Also if I were in a position to buy I would buy your car to make the decision easier haha.
If you’re asking maybe you want the top-dog?? I did and switched and happy I did
Not really. Just curious if someone that changed from a HC/CAI Z07 or Carbon to a ZR1 felt the change was worth it. The only difference in the two cars is the power plant and I wanted to try to get real world feedback on the switch. Did you have a Z07 or Carbon?
^^^ Neither - had a Z06 with PRC heads, mild cam, intake/tune @ 525 rwhp. Loved my Z, really no issues other that that pos MSD intake which I removed but I will be honest, wears you out reading about LS7 head/guide issues........and there is something special about owning the ZR1 which has plenty of potential - at the end of the day, only you can decide what you want. Good luck with your decision!
Thanks to all for the feedback, I really love my IO Z07, and I like it even more now with the heads addressed and the additional power. I just have never driven a ZR1 and am curious if it pulls as hard as a modified Z06. Owning a Z07 everything else is there; mag ride, suspension, oil cooler, exhaust, radiator, etc. I appreciate everyone's perspectives. I would like to be able to race a relatively stock ZR1, maybe I will get the opportunity next season at one of the Slip Stream events.
I own a ‘13 ZR1 and have driven a couple of Z06’s.
I found the differences between the two to be found in very small degrees of feel.
The Z06 feels more biased toward track with a bit less weight and a NA engine with seemingly linear pull to higher rpm.
The ZR1 seems more biased to GT with a bit extra weight. The LS9 engine hits harder than the LS7, and progressively pulls harder as revs ramp up.
Not to say the ZR1 isn’t a very capable track car, it is. It just feels ever so slightly more GT.
My feeling is the ZR1 is a bit more “Jekyll and Hide” in character.
I suspect a lightly modded Z06 would have similar acceleration times to a stock ZR1 - they’re close in stock configuration - so the more capable driver would be the winner.
RedZ4me (10-23-2018)
Can I be the guy who would like to own both?
I don't ever think I'll sell my Z06, I'm just head over heels for the car, but I do have a desire to own a C6 ZR1 along side it one day. I loved the comment above about the ZR1 feeling more like a GT-type car, where as the Z06 finds itself most happy on the road course. Win-win.
