Install new starter video tips/tricks c6z
This
I will post below if this has solved my hot start/ heat soak issue. Also will explain in more detail what I think was going on (if I fixed it).
Be safe, have fun.
Froggy
Be safe, have fun.
Froggy
RossN (10-27-2018)
One thing I did for your lock washer idea was I got 2 nuts that are all metal lock nuts (the nylon lock nut would met under there) for the big starter wire terminals. You are right over time with the heating and cooling the nut will eventually work its self loose.
froggy47 (10-27-2018)
