C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Building the worlds largest LS - HPR527
Old 11-20-2018, 06:49 AM
MickVette
MickVette's Avatar
St. Jude Donor '13
Originally Posted by Apocolipse
Longer rods to slow the piston due to high stroke leaves very thin crowns
The top of the piston looked like it was a low compression piston.
What an impressive creative beast!
Old 11-20-2018, 07:25 AM
Apocolipse
Apocolipse's Avatar
Received 1,284 Likes on 929 Posts
Ah yes I see what you are talking about - quench would be my guess as well. Attempt in making the combustion chamber "smaller" to reduce chances of det.
Old 11-20-2018, 09:41 AM
Pb82 Ronin
Pb82 Ronin's Avatar
Just out of curiosity...how far out of the bore is the piston at TDC? And what thickness of head gasket are you using?
Old 11-20-2018, 09:51 AM
0HP RESEARCH
Former Vendor
HP RESEARCH's Avatar
All in due time, and do remember we are doing an inside look but not writing out a complete receipt to do at home too...
This is the lower compression of the two engines as it will be more street duty for this setup. The heads, which you will see in future posts have a rather small chamber size so a full dish is about the only way to go in getting it to work on a pump fuel using these heads. A more traditional style Brodix LS7 or similar would allow closer to a flat top piston.
Old 11-20-2018, 12:02 PM
RACER7088
RACER7088's Avatar
This is Erik of HPR, but yes this particular 527 is for a customer that has a different head and they need a certain amount of dish to get down to a streetable sub 12 to 1 compression ratio. Between the piston and head and head gaskets used we can achieve about any compression ratio we want with or without quench depending on application. If you are stuck with a quench type engine that's small you need to manage quench but on these engines we don't really need quench as much as a small engine will or it won't make much compression. Most modern engines have very little to no quench nowadays not just power adders unless they are very small or very short stroke and then they are stuck with quench and have to manage it so it doen't end up in a bad zone.
Old 11-20-2018, 12:40 PM
FNBADAZ06
FNBADAZ06's Avatar
13:1 or go home !!!!
Now it makes the 468 you're building me seem puny .......
Old 11-20-2018, 07:39 PM
0HP RESEARCH
Former Vendor
Your 468 isn't going to be anything to sneeze at either!!
Old 11-21-2018, 05:30 PM
0HP RESEARCH
Former Vendor
One more peek into the 527 builds before the holiday
Old 11-21-2018, 06:12 PM
FNBADAZ06
FNBADAZ06's Avatar
1.006" lift
Old 11-22-2018, 01:12 AM
choppychop
choppychop's Avatar
Sub'd
Old 11-22-2018, 08:22 AM
double06
double06's Avatar
Anthony, can the CID head be used in a street or should I say factory components situation. Also is the chamber volume so small that you really need a build specific piston for this head. Just trying to se if this can be a bolt on situation. I also realize given the enormous size of this engine it needs a really big head.
Old 11-23-2018, 09:28 AM
0HP RESEARCH
Former Vendor
CID offers a couple different styles of LS head, this is the larger oval port style. Looking at this particular setup it would have to be a solid roller cam setup as it will have to use a offset lifter for pushrod geometry / clearance. Not sure about the rectangle port version, it might fit a little better but we have not used one yet.
The CID head is a system and you have to know what you are doing with it, it isn't a bolt on affair for sure and you can get yourself into a lot of issues and/or engine damage if not paying attention with them. Depending on how things turn out with these we will work on a package using other CID heads as kits for our customers. It will have to have a custom piston no matter what you do, not only due to the chamber size but also valves.
Old 11-30-2018, 09:01 AM
  #33
0HP RESEARCH
Former Vendor
We have been assembling both engines and they will be on display at PRI this year at the ARE dry sump both and CID cylinder head booth. If we don't get time for installment #1 on the write up before PRI, the build will start when we get back.
Stay tuned!
Old 11-30-2018, 09:20 AM
  #34
JDebler
JDebler's Avatar
Originally Posted by HP RESEARCH
We have been assembling both engines and they will be on display at PRI...
I'll stop by and talk to you guys about it!
MTPZ06 (11-30-2018)
Old 12-01-2018, 12:28 PM
  #35
0HP RESEARCH
Former Vendor
Sneak Peek before the show.
Write up will have to come after we get back from the show.
Old 12-13-2018, 04:31 PM
  #36
0HP RESEARCH
Former Vendor
Finally getting caught up after PRI so look for edition #1 coming here in the next day or two.
Old 12-13-2018, 05:43 PM
  #37
Innovate
Innovate's Avatar
Subbing. What block do you use for this?
To Building the worlds largest LS - HPR527
Old 12-13-2018, 06:22 PM
  #38
JDebler
JDebler's Avatar
Aw shoot...I was doing an interview eight there at the Dart booth and then walked right by the engines. I knew I had missed something when I was driving home...
Old 01-02-2019, 12:09 PM
  #39
0HP RESEARCH
Former Vendor
Where to start, I guess the easiest point would be at the block and work our way through that.
A bit of history should be explained first. As some have already pointed out there is another big LS out there that is also listed as a 527 from a company in Australia that is more of a dedicated race only deal, sold for around $100k. Ours is only slightly larger and should be selling for a bit less than a six figure price tag, although it could very easily get there depending on options and how far you wanted to take it.
During this write up you may see pictures of two different engines and there are two going together at the same time. One is a more 1/8 and 1/4 mile setup while the other will be a street / strip / drag week kind of build. Both are going to be a bit on the aggressive side, make no mistake about it but the end goal will be to have the drag engine well past the 1000hp mark (flywheel). There are going to be a few items that will NOT be given in exact details. Final stroke, rod length, or piston design will not be given during our discussions but you will see pictures of them of course. So here we go......
Part 1: The block
When building an engine of this size, your choices on engine blocks are far and few between. Since we are dealing with a crankshaft well over 4.500" of stroke, it will have to be a tall deck to handle this kind of stroke. In the tall deck range of items you have the LSx, RHS, Concept 1, and Dart blocks to choose from. We wanted to have a few more options for cam size selection and it needs to be raised to be able to clear the connecting rods. Being a raised cam eliminates the LSx, and at the time the Concept 1 block but they are suppose to have a release on a raised cam block. For these two builds we decided on the RHS being we have done some big stroke setups in these blocks before and have not had any issues with them.
RHS block out of the box
As the blocks come, they feature a 0.388" raised cam location, 55mm cam bearing journals, std LS main journals, 9.750" deck height, billet main caps, cam retainer plate, rear cover, and plug kit. They will accept OE wet sump, OE dry sump, or aftermarket dry sump oil systems as well as OE style timing chains. They do require the use of a link bar style lifter.
Once the blocks are out and inspected for damage during shipping they head directly to the boring bar to rough size in the cylinders. The blocks ship with a rough size of 4.120" and we are having to bore a bit larger than that.
Boring each cylinder to rough size
Once we have the cylinders roughed into size the blocks are placed on the surfacer to check deck height and milled perfectly flat. Once finished there, they go into the hone with a torque plate and cylinders are brought to their final size and surface finish. Now that we have a workable cylinder that will accept the piston they are mocked up prior to the mill.
Blocks are clearanced for stroke in a number of places.
First the crank is laid in place and spun to make sure there are no issues with the crankshaft itself.
Once the crank is free and clear, we install one rod and piston into the block and check for proper clearance, machine as needed.
Now these are done in a little different order than your normal 416/427/454/468 build in that typically we take the blocks directly to the mill first to clearance the block and cylinders for the increased stroke. When dealing with this many custom parts and displacements of this size we have to mock it up and cut as we go to insure we are leaving as much material as possible for strength and support. To add to that, each of these two blocks have shown some variation to them inside the crankcase and we increased stroke slightly from the last build, so EVERY 527 will have to be checked, clearanced, and checked again as needed to make sure everything fits nicely before clean up and assembly.
Now that we are sure the rotating assembly will have no problems turning over, we bolt all of the main caps back into place, torque to spec and check the main housing bore size. If needed the blocks are line honed to size before moving to the final steps before wash.
A couple steps added to the race setup. (#bigboned) We are going up to a 60mm camshaft journal from 55mm (stock OE), machining the front cover for a Jesel belt drive, and installing 0.937" diameter key way Jesel lifters due to the larger camshaft this engine will be using over the other. These steps are vital on a higher RPM, big lift engine to help remove stress from the valvetrain, allow a larger base circle cam and help to remove some harmonics from the valvetrain. More on that later.
60mm babbet cam bearings installed (still have room to go larger if needed).
Front cover machined for Jesel belt drive
Jesel 0.937" keyway lifter bushings.
Once both blocks were finished maching they are washed by hand / pressure washed to insure no debris are left behind in any part of the block, blown dry and moved into the assembly room for prep.
Final block wash by hand / brush / pressure washer outside and in.
Next step is laying out the rotating assembly and bearing clearances.
MTPZ06 (01-03-2019)
Old 01-03-2019, 03:26 PM
  #40
0HP RESEARCH
Former Vendor
Part 2: Rotating parts
A key component in any build is going to be the crankshaft. Many think cranks are cranks. You have cast and forged....stock and stroker, but there is far more to it than that. Given no one makes a crank in this stroke for the LS engine, it had to be a custom billet piece no matter what we did. Callies, Windberg, and Bryant Racing all provide services to build one off or small runs. Given we have worked with all of these in the past, we felt Bryant Racing to be the best at what they do on custom units like this.
HPR 527 LS crank by Bryant Racing
Now you might notice a few things on this one in that it looks a bit different than your standard LS crank, apart from the bigger than stock stroke. It has more than 6 counter weights for one. This is a 8 counter weight, or center counter weighted (ccw) crankshaft, being that every pair of rods now has a counter weight to balance it out. These are going to be heavier than your normal forging but offer a number of benefits from a stronger crank to one that has far less natural harmonics in it to shake the engine. We typically use these on any of our forced induction builds making over 1000whp, or any engine that is going to be turning higher RPM's for a longer period of time. That isn't to say it is the only reason as cranks such as these tend to flex less and offer longer main bearing life than their 6 counter weight brothers. Given our drag setup might see north of 8000 RPM and over 1000hp, again it made it a logical choice to go this route.
A second thing someone that has been around this might notice is the number of pieces of heavy metal. Bryant spends a lot of time designing the crank to offer the best way to keep the crank strong and fan height for the counter weight to offer natural harmonic damping. That being said we are using a relative light rod and light piston in these engines so bob weights are even lighter than what you would find in our 468 builds by 10-20 grams and lighter than more normal forged 416 build by more than that. That all being said a number of pieces of Mallory were needed to bring the crank into balance. Those working up a rough $ in your head, there is more cost in the heavy metal in one of these cranks than a stock LS7 crank is new.
Connecting rods.
For now we are using a custom Callies forged H beam rod with a few changes to it. Moving forward, HPR 527's are going to have our own connecting rods built for it as we have found a number of ways to improve upon the design, and take some weight out of the rotating assembly while maintaining strength.
Forged H beam rod
ARP 2000 7/16" rod bolts are used in the 527 as in most of our builds
What you have seen so far will be included in any 527 as the crankshaft and rod combo will be the same in all of them. Pistons however, we do have a few options and every customer engine will have pistons spec'd to his/her needs and application. This pair will be using Wiseco for the drag engine and CP for the street/strip combo. Each piston was done to our specs and designed by Erik and each respective company.
Street/Strip by CP.
HPR 527 piston by CP.
With the CP piston we did a number of things to strengthen and lighten the piston both at the same time. As in 99% of our builds it is a 2618 forging material, but we decided to do a strutted piston with a number of CNC lightening features to bring these in under 400 grams. By comparison the OE LS7 piston is 483 grams and most flat top forged aftermarket pistons are going to be north of 440 grams! A slight dish on these will allow us to bring the compression under 12.2:1 for normal pump gas mixed use that this will see.
support struts and milled pockets.
Above you can see the support struts going from either side of the pin boss down to the rail. This greatly strengthens the pistons tenancy to bend around the pin boss and bring strength to the sides of the piston since we are not using a "full round" piston that would have a skirt going all the way around the piston (which isn't needed thus helps reduce friction and weight by not having a full round). You can also see the pockets milled to either side of the pin boss to remove weight, and this was also done above the pin and under the head of the piston for not only weight removal but to make the piston as balanced as it can be around the pin so it will not have a natural rock to it on the rod.
Drag by Wiseco.
HPR 527 drag piston by Wiseco.
Wiseco's pistons are also a 2618 like all of their professional series pistons that we use. Unlike the CP piston this is a normal flat top design with the correct valve reliefs needed for over 1.000" of valve lift and the CID cylinder head valve location. Being the CID heads offer a rather small chamber size a dome was not needed to reach our desired compression which is north of 13.5:1 on this build.
Under side featuring full under head milling
You can sell the full under head mill on the Wiseco piston above. Again, all done in the name of weight and balance.
Piston pins
DLC coated piston pin
Both engines are running a rather thick walled piston pin, to control deflection of the piston at the small end of the rod. On the CP pistons, since it is more of a boxed design which will block some of the oil splashing up to the pin we added a bit of safety by going to a DLC coating on these. The DLC will help prevent the pin from galling to the rod bushing or the piston itself in the event there is lack of, or reduced oil flow to the pin. The Wiseco pin, is the same size, but un-coated since the piston is open on the bottom side and will have more than enough oil feeding to it. You might ask, why not do it on all engines? Well the DLC coated pins are typically 1.5 to 2x the cost of your normal tool steel pin which is already double what a typical pin is going to be. So it boils down to a costs vs benefit deal.
Rings.
In most of our custom piston designs we like to use a Total Seal Ring pack (not the gap less rings) because of their ability to provide us a number of custom features, sizes, and tensions. Following along in the trend of racers as well as the high performance OE designs we are running a smaller ring package. Top and second rings are slightly thinner than 1mm with a 2mm oil ring pack as you would find similarly in a OE LS7 package. Controlling skirt design, piston to wall, and ring tension we can do this and still have excellent sealing and oil control with these big engines, just as GM was able to do with the LS7 using a thin ring stack.
Ring lands
Total seal rings
Main and rod bearings were covered by Federal Mogul, and were coated for added protection.
The following 5 users liked this post by HP RESEARCH:
Che70velle (01-03-2019), FNBADAZ06 (01-04-2019), MTPZ06 (01-03-2019), Racingswh (01-03-2019), TRSCobra (01-04-2019)
Quick Reply: Building the worlds largest LS - HPR527
