[Z06] Anyone use nutserts when installing their side skirts
I am considering adding side skirts but would like to be able to remove them if damaged without having to drill out all the rivets. Has anyone put their skirts on with nutserts?
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I would not use 3m tape to hold on your side skirts. Not only is gravity pulling down on them but the sideskirts themselves generate a small amount of downforce that further contributes to their tendency to want to fall off the car. This tendency is further exacerbated by going over bumps in the road and/or improper surface preparation when using tape. Install them using rivets, which fastens them to the rockers squarely and securely. In this application you want a mechanical fastener.
Good companies like C7 Carbon and ACS ship them with rivets for a reason. It takes literally 2 seconds to drill out a rivet, which is as much time as it took the OP to make this post questioning drilling out rivets and as much time as the next poster suggested to use 3m tape.
jayyyw (03-19-2019)
Mordeth - I understand where you are coming from however remember that the front of the skirt is bolted at stock location and the rear of the skirt is riveted in place to the wheel arches. The only part unsupported is the middle. If by some reason the tape let go those 2 solid mounting points would still hold the skirt up.
I felt this was perfectly fine and went 3m in the mid section - others may not feel the same and they are free to do as they wish. However I am using the strongest tape they offer - i would not trust cheap shitty stuff.
OP: Just use rivets and properly secure the entire length of the piece to the car as the manufacturer intended. The part is designed (even from GM on the ZR1) to be entirely supported by mechanical fasteners. If they need to be drilled out then drill them out and don't fret over this task. This is not difficult work, I assure you. If you have a drill and a bit set and aren't disabled then you can accomplish this simple task. You use a bit that is just slightly larger than the hole in the pop rivet and drill just enough to remove the head. The rivets will come right out and anything left behind can be extracted.
I used screws to attach my side skirts. They have been on for almost 10 years with out any issues.
Also keeps debris from getting between the rocker and skirt and takes up any gap between the front fender and rocker.
And if you ever wanted to remove them there would be no evidence at all. No paint scuff, holes or possible cracking.
I'm still thinking NUTSERTS or RIVNUTS might be a good way to go on securing ZR1 skirts to Rocker Panels
Were ALL the Years of C6ZR1's Riveted (Skirts) or did any use those Plastic SCRIVETS
Rocker side skirt
Really I'm surprised some of you are just using a 3M double-Sided tape because is really exerting a downforce and gravity will always pull a down force as well. I have my blade spoiler using double sided 3M tape and some silicone adhesive and the 3M tape is not holding it well smh!!!
3m makes a lot of different tapes - if you do it right there are no issues. Do it wrong and they will fly off. Plus...there really is not much downforce acting on them at all.
Plus - they are bolted at the front and rear...so the tape just supports the middle.
https://www.corvetteforum.com/forums...post1598255513
https://www.corvetteforum.com/forums...post1592490261
I've decided to use ALUMINUM 3/16" Rivets with 5/8" Dia Heads...
I have a MARSTON Rivet Gun that takes a pretty good bit of force to pop
the Rivet But can be done.
I mocked the KAPALINI (Ebay) Skirt in Place with a couple of Rivets on
Each Side and then easily removed them by drilling a bit of the center out
and then using a thin putty knife and hammer the 5/8" Head sliced right off.
I found that any remaining (drilled out) Remnants will exit the rocker panel
thru misc opening if you back up and apply the brakes hard...
Notice that Im using the OE/GM Flares that I bought online for $216 as I dont
like the unfinished side of ANY of the Reproduction Flares (Mudflaps)
Flare Hardware in the one picture is just temporary. Ive found some nice GM fasteners
and U Nuts in salvage yards vs the Incredibly high on line prices
If you doubt the hold of the tape try taking the front emblem off.
Mine has not blown off yet.
Would I use tape on a front spoiler? NO
Do whatever makes you feel good, I prefer not to drill holes and rivet, etc.
Has anyone used a specific type, size, part number of SCRIVET
to Hold Skirts onto Rocker Panels tightly.....
https://rover.ebay.com/rover/0/0/0?m...2F232745188880
HouseS2k, Asking IF youve removed/drilled the plastic Rivits Out vs The 3/16" x 5/8" Dia Head
ALUMINUM Ones Im ready to use now......
The Aluminum Heads Drill Out and Shear off easily but I was thinking the Scrivets would be better yet...
Share more knoledge about applying and REMOVING the Plastic Rivets that LOOK very much like the
Aluminum Ones
Aluminum Ones
Aluminum Ones
Aluminum Ones
