Anybody using Southways 108mm TB?? Having problems with it
The 108 comes with an adapter that must be used when bolting on to a traditional 4 bolt throttle body flange, as the Southways unit uses 8 bolts. This effectively spaces the 108 tb further away from the mouth of the intake
This new MSD intake he is trying is not a stock Mamo ported MSD. It has been extensively modified by another "porter"
Possible a bad motor, but it was a completely new throttle body and motor and apparently worked fine when tested on a LS3 build (I think is what JayyyW)
it was a mamo msd thrn sent to some other person who went to town on it. So saying this is a mamo msd is not even close to accurate. He should have stuck with the mamo.
FNBADAZ06 (02-04-2019)
I got everything figured out HP tuners had to add a file. Needless to say it makes this exact same horse power
There was no horse power difference between the two set ups
So are you now back at 680 hp?
Yes, he's back to generally the same power.........675+ on the last pull is what he told me this morning.
The 102 tb is not the limiting factor with the MSD intake. When we finally test the new FAST, I suspect the 108 will show some minor improvement.
Now I’m at 730rwhp
