Head choice
Head choice
2010 Z06 48K, no problems to date! Just decided to go ahead address the potential valve guide issues. I’ve found these repaired heads on the forum vs possibly just going through AHP and purchasing there heads. The repaired heads listed is priced without swapping out stock LS7 heads which I can resale for around $1,000.00 to recapture some of the expense. I don’t foresee me drag racing the Z, but would like to feel comfortable about the heads and possibly do a mild cam upgrade for the streets. What’s the pros and cons of purchasing a quality heads as mentioned below vs heads from AHP or possibly sending my heads off to Total Engine Airflow for rebuild?
1) LSX-LS7 6 bolt heads fresh from the shop with Ti intake and new Stainless exhaust valves. New guides/seals. Chamber size 57cc. BTR spring kit. $2500
OEM rockers with trunion upgrade $250
2) LME fixed LS7 headsHeads have, roughly, 2500mi since they were done by LME. PAC .660 lift springs, stainless exhaust valves, OEM intakes, new guides, ported, and milled to roughly 64.5cc. $2500 plus shipping and fees
TSP 7.750" pushrods. Have the same mileage as the heads. $75 shipped
ARP headbolts. Torqued twice. $100 shipped
3) SPS ported/Fixed ls7 headsFresh stock casting ls7 heads from SPS. They have stainless exhaust valves and powder metal valve guides as well as their CNC porting program. They have not been bolted on an engine yet since all work was done. $2200.00
4) AHP heads....Package 4 LS7 Cylinder Heads
$1,573.00
Read moreAHP Hardened PM Valve Guides
New Stock LS7 Springs
No Porting
$1,573.00
- AHP Hardened PM Valve Guides (+$0.00)
- Moldstar90 Valve Guides (+$600.00)
No Porting
- No Porting (+$0.00)
It all depends on who these so called quality heads are built by. I trusted AHP and that's who i went with. To me I feel better knowing they have done countless heads for the LS7 and for that reason I feel comfortable with their work. You can get fixed heads from them for under 2k. It's a no brainer to me. Good luck!
Yup! Big fan of AHP! Outright superior customer service and they are probably the number one shop doing LS7 heads. MS90 Is also and nice feature almost exclusive to AHP. My Z made some serious power with there set up too! If your on the fence about which one give Khole a call.....I have a feeling it’ll push you on the right direction. 🇺🇸
You will probably have an over welming response to going with AHP heads. Like I said they do hundreds of LS7 heads per year and I havent heard of any that have failed. I recommend you give Kohle a call and just chat. He is very friendly and easy to talk to and will be happy to answer any question you have. He will even make a recommendation on what head setup is best for you without trying to upsell you to something you won't need. I planned to stay relatively stock so he recommended his package 4 heads with powdered metal guides and no additional add ons. That still includes the new ferra exhaust valves and tumble finished intake valves and a performance valve job. I the end it's your decision on what you do but I recommend looking at all options before you pull that trigger. I would rather spend a little more now than regret it later.
Don't put used heads on your LS7. Unless you pulled them straight out of the box from someone you'd literally trust your motor with, I'd suggest you send used heads out to a competent machine shop for inspection.
Me personally, I'd go with AHP for their Moldstar 90 valve guides alone; I'm a big fan of the Beryllium-free copper alloy and it's thermal-conductivity properties. Look up the links below and educate yourself more on it, it's pretty fascinating. There are handful of different companies who offers great heads that you probably couldn't go wrong with, but what set AHP apart from the pack for me was their knowledge of the LS7 specifically. The LS7 cylinder head is the beauty behind the entire motor, and it's not simply just another LS cylinder head. AHP has a great new CNC porting option now that rivals the best out there, and regardless of whatever heads you do choose, I'd suggest you to consider PSI or PAC valve springs and Ferrea exhaust valves.
http://www.moldstar.com/MatlApplications.html
http://www.moldstar.com/MotorsportApplications.htm
Formula8 (01-29-2019)
Thanks for all your personal experiences and recommendations with LS7 heads. I will take your suggestions and chat with Kohle at AHP for his guidance. Like Allstate I think I will be in good hands! Happy Motoring......
Ill give a good example: when I spoke with Kohle and gave him a run down of my goals the build and my cars intended use I let him know I’d also be changing cam’s and asked if they could do that as well. He replied of course we can and told me about the cams they offer and explained picking the right cam for my car. After he did that his next response really surprised me.....he straight up said to me, we can provide a cam for you and our cams are great! How ever in your situation with you build and goals there is a “best” option out there and that may not be us. He gave me a few recommendations and I went on my quest!
I’m pretty convinced for my needs this is the way to go:
Go with AHP’s Package 4 Cylinder Heads (includes):
- Disassemble and Assembly of LS7 cylinder heads
- Performance Valve Job (show to add 5hp+ over the stock valve job)
- Resurface Heads (or milling of heads)
- Clean and Bead Blast entire head (so they look brand new)
- Hardened Aftermarket Powder Metal Valve Guides (Harder than aftermarket bronze guides)
- Stock Titanium Intake Valves Treated and Polished
- Ferrea Competition Plus Exhaust Valves F2042P (85 grams)
- New Viton Valve Seals and machined valve locks
Total price for American Heritage Package 4 LS7 heads: $1,358 (plus return shipping W/insurance)
Plus upgrading to to the MS90 guides. Using there head install kit.
That will definitely take care of you, now if I may....help you spend a little more of your money lol(this forum is great at that!) doing the CHE trunion upgrade is smart “while your in there”(that phrase pops up a lot) and if you can swing it scrap the GM lifters and upgrade. I’d recommend the Johnson 2110’s personally. If you add those two upgrades to the package 4 you’ll be looking real good man! Kind of a preemptive strike on some known weak points, take them out before they have an opportunity to get you.
Those LME's sound like Jayyy's heads, I would run them. LME builds some great things.
Johnson 2110's are the least in lifters you should do.
