30 profile tires on 20" wheels!
I'm going to buy Michelin PS Cup 2 tires, but in bigger than OEM size: 325/30-20 or 345/30-20. I am not speaking of 3xx/25-20.
Can this be done without rubbing, and if not, can the liner be modified to make it work? Car doesn't have to be super low, but wheel arch needs to follow tire quite nice
If you have pictures of this on a C6 Z06/ZR1, please post it!
Edit: I have the OEM cup wheels
Both of those are going to be a 28" tire. The car will modify the fender lines itself as they rub. Probably rub into the battery box and other areas too if you are not careful. You also need to match the front wheels to those size, as you will get errors if you do not as the tire sizes have to be within a few percent of each other.
Basically not a good idea. Plus it kills gearing and makes the car slower.
What's the overall diameter change?
I run 325/25R21 rears (about 3/4" taller than OEM size) and my car is lowered all the way on stock bolts. Every now and then, over very large dips, they'll touch the inside of the rear fenders.
Look at the tire manufacturer specifications, sizes are approximate and using a tire size calculator may not be accurate enough. Michelin data says their 325/25/21 is actually 27.4" tall, not sure why you calculated 355/25/21. Anything over 27.5" is pushing it.
WHY do you members REJECT my C6 Grand Sport Set Up
that Luke from Tire Rack suggested to me
345/30-19 on 19x12.5
295/30-19 on 19x10.5
I just received my SIGNATURE SV701 Wheels and dont have the tires mounted yet
Chuck Sharin
Chuck Sharin
I have 360 20" wheels lowered with toyo r888r tires 285/30/20 and 325/30/20. It only rubs slightly if go over a huge bump. I think it would be OK if you at stock height and slightly lowered.
I believe the 315/30/20 r888r’s are only 27.2 or 27.5 inches tall... that’s a tire that I saw recommenced on the forum. Before going to a 25 series, I would pick that tire. Even at 12 inches wide, it’s better than any of the 25 series at 13 inches wide from what I’ve been able to find. Guys have mentioned that they drive rather aggressive on 27.5 inch tires and have gotten the rare running only from heavy bumps.
I have a set brand new that I would sell, with my Forged 360's and there aggressive offset and my car lowered completely on stick bolts they rub the fenders.
how is IT on the ragged edge in a corner with two people in the car? I am open to not lowering the car completely on the stock bolts
Ideally I would go for 19" or even 18", but I don't have wheels in that size and it's expensive, so I wanted to just buy tires. I also really like the design of the cup wheels that I have now (19" front 20" rear)
