Add E85
Add E85
Was want to know the ins and outs of adding E85. I have a 06 Z06 that is stock. Going to have the heads fixed and ported. Is there a kit to add e85 or can you just fill up and have a tune put in the car? I have herd you need upgrades to fuel pump and injectors. My car is weekend car that might see a drag strip a few times a year. Want increase in power and clean fuel. Thanks guys
DSX makes a sensor kit that is super easy to install. As for pump/injectors/etc that all depends on your power level. You may not need much, or you may need $2500+ in fuel system upgrades.
To me it is worth it even on a stock car as E85 is cheap, clean, and easy to get here. Plus helps with cooling and high octane is always good. Now if you are doing it just for power, then it may not be worth it.
The following 2 users liked this post by jammeejamm:
musclesbmf (03-26-2019),
thetastelingers (04-24-2019)
For a practical, street driven car, I don't think the pros outweigh the cons. Can you make more power with it? Sure, but the tradeoff is a hit on your fuel mileage; (think big-block with a 4:11 rear end.) Plus, a Corvette that isn't a daily driver sitting in my garage with a full tank of E85 is not good. Apparently, E85 is also extremely sensitive to pre-ignition, which is a concern on DI motors, like the GenV LT motors. Unlike a true flex-fuel vehicles, I'm not sure you can just go back and forth between E85 and Premium 91/93 without having to switch between two separate tunes. Full disclosure, I despise the Corn Lobby and ethanol subsidies that force 10% ethanol into all of our gasoline, but to me unless I'd be driving a full-race build on the track, the trade-offs are just not worth it. Ethanol is just not the solution.
https://www.corvetteonline.com/tech-...-need-to-know/
https://www.onallcylinders.com/2015/...-applications/
I've never met a single person that regrets swapping, EVER. Almost everyone agrees that swapping to flexfuel was hands down one of the best mods they have done. The people who seem to be against it always are people who have never used it, and don't seem to understand it.
The following 3 users liked this post by Unreal:
Almost everything you just said is incorrect. E85 is EXTREMELY knock/preignition resistant. The corvette support flex fuel as soon as you turn it on in the tune, so you do not have to switch tunes. The gasmileage hit is ~25-30%, not big block 4:11 or even close, but cost of ethanol easily outweighs that. The downside is just filling up more often, like 210-220 miles a tank instead of 300, but I pay $1.80 a gallon vs $3 for premium 91, so actually comes out cheaper.
https://fuelandfriction.com/weekend-...less-you-know/
- It’s susceptible for pre-ignition – Due to its ethanol component, it’s more likely to ignite before the piston compresses and the spark plug does its job.
All it takes is an impulse such as hot spots in the combustion chamber, a spark plug that runs too hot for the application, or carbonaceous deposits in the combustion chamber heated to incandescence by previous engine combustion events. This doesn’t sound like something all that bad, but it certainly is. Pre-ignition means that the fuel sprayed into the cylinder ignites before it should thus creating an unbalance in the engine internals and putting stress on components. This leads to engine knock where the combustion process doesn’t happen at the optimum time for a four-stroke cycle. The shock wave creates the characteristic metallic “pinging” sound, and cylinder pressure increases dramatically. Effects of engine knocking range from inconsequential to completely destructive as I can personally attest to.
As for the mileage, okay, maybe a 3:73 rear gear. Window sticker says 15/24 and with E85 you're down to like 10 around town and you'd be lucky to get the high teens on the highway. No thanks. And don't let that gas tank full of E85 sit for anything more than 30 days without some Stabil in it. I wouldn't buy a used car that was converted for E85, so buyer beware.
The C6 Corvette's E38 ECM has two octane tables,(high/low) but I don't believe you can just switch at the pump between E85 and Premium - it's one tune at a time. There is a big difference between 108 octane and 91 so why would you even want to run a tune for both?
You are wrong. ECU supports flex fuel and will blend fuel and octane tables between the spark map and flex fuel maps.
Preignition is not an issue. No more than on gas. Yes it has a low preignition temp than normal gas, but if you have that issue, you are running the wrong plugs or a complete crap tune. This isn't something most people have to worry about. Don't make anything a glowplug in your head, and it is a non-issue. You can make the same argument that gas can preignite and take out a motor if you have a crap chamber, hot points, wrong plugs, and complete **** tune that allows stuff to get so hot that preignition becomes an issue.
Once again, someone who has never used it spreading bad info. Reminds me of antigun people that have no clue what they are talking about.
Z06Kevin (04-21-2019)
https://forum.hptuners.com/showthrea...l-timing-wrong
To each their own, I'm just trying to point out that E85 doesn't come without some negatives. Me personally, I wouldn't use it just because of the bad taste left in my mouth that the Government gave me with the E10 mandates; the Big Corn lobby can shove the corn up their tailpipe. Throw in the lower energy content and it's subsequent less fuel mileage, on top of its corrosive tendencies, it's like a short-travel lifter for the street - if you're not running under a stopwatch (or on a dyno all the time,) can you really tell the difference?
That's one of the reasons I never saw the great appeal in E85, because I thought it would be silly to tune your car to be confined to E85 only. You still have to be careful about letting E85 sit in your tank more than a month or so at a time, but if you can run 91 on an E85 tune 90% of the time and your motor not otherwise know the difference, it might be interesting to have the ability to top off with a tank of E85 for a weekend drag race. I can buy the appeal in that.
Yes, flex fuel sensor automatically adjust. It adjust fueling and timing for anything from 0 to 100%.
So after all the back and forth, did the OP decide on anything? lol.
MY HUMBLE OPINION is as follows:
I havent gone flex yet on my Z but I'd really love to. I bought the car already supercharged and running on 93/meth but IMO filling up the small meth tank is silly, I'd rather be flexfuel. Every bit of research here and from tuners will say the stock Z fuel pump "can" run E85 but WILL eventually fail. Could be a month could be 6 months but it wont hold up. Also E85 flows more/more is needed to flow to your engine so very likely you will need injectors (someone correct me if im wrong).
I had a WRX that was flex fuel and i loved it. I can attest that even with the little 4cyl with only 330whp that the tank empties much quicker than 93. I have tons of E85 stations by me but def needed them all bc i was filling up much more often. But that car was my dedicated daily so thats expected. I also have a bunch of friends with imports running flexfuel. BIG hp cars though. All the ones that have built their cars recently havent thought twice about flexfuel, and i wouldnt either if i re-did my Z, but these arent stock...theyre big boosted high hp cars.
So stock Z engine might not see too much power increase. With the cost of injectors and pump install the hp per dollar ratio definitely isnt good.
And I agree dont store your car long term with a tank full of E.
Pro Mechanic
Pro Mechanic
It’s quite a bit of work out this way to use e85 as a primary fuel because of it’s availability but even with all the hassle I will never go back to just pump gas.
Buddy of mine jumped 20rwhp on E with a Hi-Ram/AI/B3 setup from 93.
Just by adding the E85 or tuning for it?
If availability near me and the tracks I frequent was not a problem I would definitely use it. I just can't get past carrying two 55 gallon drums of it to the track with me.
From what I am hearing I think I am going to hold off on e85. Where I live in Oregon we don’t have a lot of good tuners in the area. I think there are upgrades that have to be made or not depending. So until we get so high performance tuning guys in the area I will be running good old 91 octane. Thanks for the debate!!
