2 piece rotors
2 piece rotors
In my quest to get the car under 3k lbs I've been looking at getting some 2 piece rotors to help drop some weight, and in a good place as well....I was wondering if there are any other places that carry the Coleman's aside from Zip and another place called Modified Corvettes?....Both come in around $1600 shipped for a full set.
As of this posting Zip is "out of stock" while Modified Corvettes is showing stock.
The car currently weighs 3064lbs....with 17" Welds on order along with the tires and then 2 piece rotors as well as front sway removed it's looking like a 90lb weight loss, with most of all of that being unsprung weight at that....I may also do some other little stuff like wiper delete and drain the washer fluid, the car never sees rain.
Thx, Sean
Thx, Sean
There are plenty of other options besides the colemans. DBA, Gyrodisc, etc etc.
I run the zip fronts, the rears are just not worth it IMO and you can get just as good or better results IMO going to base brakes.
Used to hear good things about a place called Performance AFX selling them back when I was interested. I believe they used Coleman rings but machined their own hats.
AMT Motorsports does something similar IIRC...I think they use DBA rings and machine their own hats.
Performance AFX is still there but their prices are higher than all the others....and from what I was able to find they only carried the floating and HD rotors....not the regular 2 piece ones
I actually have a set off my car I will sell you. Approx 1500 miles on them. I bought them from Zip Corvette. Around 9lbs lighter than factory rotor. PM me if interested.
Sean_C (06-10-2019)
If I recall correctly, there's a "standard" set which is thinner than stock, and a "heavy duty" set which is the same thickness. Yes the standards are lighter, but even say on their page they're not recommended for track use. I'd never put those on my car, but hey you do you.
Sean_C (06-10-2019)
Get ahold of Ken @KNSBrakes
Yea from what I've seen and read the sets that use the Coleman rotors are the lightest ones out aside from the super expensive titanium ones.
A weaker rotor up front will worsen your braking performance and resilience much more than base calipers in the rear. I know exactly what happens in Mexico and you've got to be prepared for a 170-20 stop. Good luck with those thin rotors.
Again, your car, your choice. However, your preferences are not making much sense.
You won't likely experience a failure apart from warping the rotors without sufficient cooldown. Then your wheel will shimmy during every stop. It's annoying but not the end of the world.
I have them on my car, and rings need replaced after an event, because it tore through them so quickly. So if you don't mind the added cost of $400+ in rotor rings every event or every 10-20 hard stops, go for it.
Pretty much whats expected. Your welcome to come look at mine and how they have a huge lip after not much use. The slots are almost gone.
