Head Fix vs Trick Flow
Premium Supporting Vendor
My apologies. I will look for that post when I get time. So, in your expert context, do you have an opinion/facts on which valve guide material would be more compatible with certain valve materials? I have read numerous times that bronze is a superior material for lubrication qualities. If valves and seats are concentric, it seems the other factor to eliminate excessive wear would be reduced friction with superior guide material and properly coated valves. Unless the geometry is so horrible, it creates sideloading. Once Katech fixes a set of heads, is that the end of this particular issue? Seems like many are experiencing repeated efforts and expenses to address this problem and I am wondering why. Thank you
We have had engines come back for rebuild, checked the guides and they show virtually no wear. We recently made a video about it here:
The following 2 users liked this post by Katech_Zach:
Blackship (08-06-2022),
MPeters1961 (07-19-2019)
Yes, bronze has superior lubricity, but the chrome nitride coating on the stock intake valves is too harsh for the bronze. That is why we only use our molybdenum-coated stem intake valves with bronze guides. I wrote an article on this, which can be found here: http://katechengines.com/wp-content/...159.1559570160
https://www.youtube.com/watch?v=DpfJZqXCgSg
Thru CPR in 2016, my heads were done at WCCH with bronze guides, Katech TiMo intake valves and new OEM exhaust valves. At 12K miles after the heads were done, I had the bottom end done fully forged and the heads were sent back to WCCH, who disassembled them, did all the measurements and reassembled them, all in very good shape. I do a few 1/2 mile, 1 and 1 1/2 mile events, 90 mile events at 150MPH taching ~ 4800 RPM continuous and a few road course events running 4-7K rpm.
MPeters1961 (07-20-2019)
Hey guys! Just an update. Heard back from TEA and got measurements on my heads before they started messing with them. They said that mine “range from .0018 to .0080. We consider .0018 on up to be out of range and needing to be replaced.”
So, isn’t .0037 what everyone else says? Do my measurements above show that I was literally about to drop a valve? Eeeeekkk! If so, glad I got it in now and didn’t push it off until winter!
Ughhhhh!! I thought it was the exhaust valves that were primarily failing. Eeeek starting to really regret getting this thing..Not looking forward to having to worry about a valve dropping every time I drive it.
Nothing wrong with Trick Flow heads. I've had them on several different engines in my history. I have NEVER had an issue with Trick Flow. No reason to suspect they will be a problem on the LS. Use what your budget will allow you to.
548chevelle (08-02-2019)
After all the research I did I didn't want to deal with any factory castings so I put the Gen X 260's on my car about a year and a half ago, haven't had any issues with them. I purchased them with the 370lb springs and titanium retainers and they performed great with the stock cam. I don't have any dyno numbers but my car with a Halltech 103, 1 7/8" ARH headers with cats, BB PRT axle back and TF heads had a slight pull on a stock C6 ZR1 to the top of 4th gear. I recently wrapped up installing a Cam Motion Stage 2 cam, Johnson 2126LSR lifters and milled the heads .010". I start tuning this weekend and I'm eager to see how it runs.
