C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Cost of a zr1 drivetrain?
Old 09-05-2019, 09:48 PM
GX427
GX427's Avatar
Default Cost of a zr1 drivetrain?
Have an 08z full drivetrain im thinking about selling 24k miles. Was thinking for a decent 900whp drivetrain would be a zr1 drivetrain? what do used ones go for with lower than 30k miles? to do a swap im assuming i just need the Diff, Trans, TT, and a zr1 specific clutch? what do you think i can get for a 24k mile tr6060 diff trans and TT? upgraded with LG billet couplers just put them in. Or should i just go straight to a RPM trans and diff instead of a zr1? ill only be on the street with some sticky tires eventually 15 inch.
thanks
Old 09-05-2019, 10:36 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,793 Likes on 1,134 Posts
Why not just sell the Z06 and buy a ZR1? Unless the drivetrain is in something other than a Vette?
GX427 (09-06-2019)
Old 09-05-2019, 10:41 PM
GX427
GX427's Avatar
already have a fully built engine and YSI so thats far from a choice but yeah if i could go back i would
Old 09-05-2019, 11:05 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Just skip ahead right to RPM.
GX427 (09-06-2019)
Old 09-06-2019, 09:00 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
What Mike said... I am getting ready to pull the trigger on an RPM 4L70E w Yank SS3600 stall for my TBSS... Can't go wrong w RPM...
The following 2 users liked this post by TXGS507:
GX427 (09-06-2019), MTPZ06 (09-06-2019)
Old 09-06-2019, 11:12 AM
VetteVinnie
In your CBM?
GX427 (09-06-2019)
Old 09-06-2019, 11:44 AM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
No reason to go through that, when it would be easier/cheaper to just upgrade what you have.
Only difference is the zr1 rear case is stronger, rest of it is easily fixable or the same.
There is no zr1 clutch, only reason they are different is for ls9 flywheel pattern is different, so you couldn't run a zr1 clutch flywheel anyways without swapping cranks. Torque tube and the rest is all the same, so no point.
GX427 (09-06-2019)
Old 09-06-2019, 11:58 AM
Rokket
Rokket's Avatar
Originally Posted by EViL427
In your CBM?
Old 09-06-2019, 03:44 PM
GX427
GX427's Avatar
Thought the TT was a inch shorter? Could I mate a zr1 trans to my diff? I talked to rick transmission and he did say the zr1 stuff is stronger inside and out I’m pretty sure.
Old 09-06-2019, 03:46 PM
VetteVinnie
Originally Posted by Rokket
Wasn't sure what that meant. Now I'm guessing Trailblazer SS. I was only half teasing, anyway, because I knew he wouldn't do it.
Old 09-06-2019, 04:06 PM
strigs21
strigs21's Avatar
I have a level VI RPM 4L70E in my TBSS with a Yank PTB3600 and i haven't had any issues with it. If your on the fence with the decision id say do it. My stock trans didn't last long. The level VI is mated to a H/C/I/ forged 402 stroker and is performing flawlessly.
TXGS507 (09-06-2019)
Old 09-06-2019, 04:16 PM
Unreal
Unreal's Avatar
Depends on year, not zr1 or not. They changed torque tubes lengths one year, I think 08+.
Yes you could use your diff for a zr1 trans, but the trans isn't better per say, just different ratios, which for most suck *****.
GX427 (09-06-2019)
Old 09-06-2019, 04:21 PM
TXGS507
TXGS507's Avatar
Music to my ears....
You won't get any love from these Corvette guys... That built 4L70E along w the Yank and the AWD these things are a blast. Mine is a DD....
Old 09-07-2019, 02:23 AM
GX427
GX427's Avatar
Contacted RKT its about 5k to have the diff and trans built for 1000whp with a wavetrac seems decent. wondering what i should run for axles definitely dont want to spend 2k on axles. Maybe zr1 axles if they fit? or get Gforce down the road?
Old 09-07-2019, 02:30 AM
strigs21
strigs21's Avatar
I think I've seen a couple of your posts over there on tbss forum. Beautiful zr1. My tbss is actually for sale because i want to see about getting into a zr1 as well.
To Cost of a zr1 drivetrain?
Quick Reply: [ZR1] Cost of a zr1 drivetrain?
