Mag Ride update by Jim Mero
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
Got the Mag Ride software updated by Jim Mero yesterday, and it was immediately noticeable. It doesn't make the car ride like a Cadillac, but there's a noticeable improvement in the ride in both Tour & Sport. On smooth streets Tour will probably feel about the same, but on rough roads with dips, bumps, broken pavement, patch jobs, etc, you'll immediately be able to tell a difference as the car will absorb them much better. As to Sport mode, you can now use it. It honestly feels very similar to the new Tour mode on smooth streets, but you can tell the car is controlled better. You can now use Sport mode as your everyday driving mode. Overall the upgrade is very similar to what GM did on the C7 Mag Ride cars with their updated software.
It's not that the stock ZR1 Mag Ride tuning was bad, it's just that Jim's tune makes it even better. I have a 2 lane backroad near my house that I drive constantly (use it as my primary route to avoid a major road that gets backed up). There are a lot of patch jobs (some not very good), rough spots, bumps, etc. With the stock tune and using Tour, you feel every one of them, and I would cringe when I hit some of them. With Jim's tune on Tour, it's almost like driving a perfectly smooth road. Most of the impacts just disappeared, and it let me enjoy driving the road much more. It also made the car more stable as many of these impact occur mid-corner, and it used to upset the car causing me to have to make a steering correction. Now most of these impacts just don't bother the car at all, and no longer need any steering adjustment.
If you've been thinking about doing it, don't wait anymore and get it done. If you haven't looked at it previously, you owe it to yourself to consider it. The GM Mag ride update was the best mod I did to my C7, and I'd say the same thing about Jim's update to my ZR1.
https://jimmero.com/
The following 7 users liked this post by EvanZR1:
JABCAT (12-22-2020),
Jim Mero (12-23-2020),
leadfart (12-22-2020),
passagemaker43 (12-22-2020),
tonysz06 (12-24-2020),
and 2 others liked this post.
I concur. I had mine done about an hour before you did. The impact of the updated tuning is noticeable right away.
It is truly the best of both worlds... succinctly stated, it provides more comfort and control. Tough mod to beat dollar-for-dollar.
If you can get with Jim in person, he can do it through the OBDII port. Takes like 5 minutes. Otherwise, you'll have to get the recalibrated MRC module, which he said takes less than 1 hour to install.
Jim came by and did mine this morning. It's misty out, so not conducive to a spirited test drive today. I will say on the five mile trip back to my house, there were certainly less squeaks and rattles! It's a no-brainer mod, especially when the mod creator comes to you!
The following 3 users liked this post by leadfart:
Hello wjnjr
Just FYI, we will be in Houston until the morning of the 27th when we will be driving to Florida.
If you are interested, feel free to contact me at jim@jimmero.com
Thank you, Jim
ZR1 136 (12-26-2020)
Oh my gosh Jim, what a difference! Shortly after your MRC upgrade, I traveled 18 miles north to La Grange, Texas. The New Tour setting took out the harshness of any bump or dip and the steering response was noticeably sharper. When I approached the bluff, I switched to the Super Sport setting, which allowed me to carve up the 6 turns of the bluff at a speed I didn’t think possible! I had so much fun, I ran it four times!
So with a smile on my face, I look forward to more spirited driving with my "new" ZR1. Thanks for breathing life into her!
Hello wjnjr
Thank you, Jim
Thank you, Jim
You should have good weather while you're here. Merry Christmas and best wishes for a successful trip.
Jim Mero (12-24-2020)
Jim,
I plan to take my car to the drag strip, front sway bar is removed, everything else is factory, would this update benefit me any or not really as much on the drag strip?
Had mine done 12/24/20. Definitely a noticeable improvement! Touring mode is much more comfortable to drive/ride. Super sport mode is a blast with excellent feel! Had a chance to test it out on the toll road and was definitely a marked improvement!
I hope to have him upgrade my car early next year. I wasn't able to meet him on his current trip, my car is up on jack stands in my garage.
Admittedly, I have never done any drag racing. If more front lift is desired at launch, I would suspect that removing the front bar would help because of the bushings. There is a 2 mm interference between the bar in the bushings. So, removing the bar will eliminate the amount of grip the bushings have it theoretically allowing the car to lift more.
Hopefully, this year, we will have custom drag calibrations. If you are interested, I invite you to visit my website www.jimmero.com and fill out your information so I can contact you when they are complete.
Hope that helps, Jim.
Hi Denis,
I'll get it filled out and we'll talk when the time comes, thank you again!
