[Z06] Transmission,differential,power steering AN lines and fittings
I need some help figuring out what fittings I would need the sizes in particular for the pictures listed below I think -6AN is plenty to 3/8? But what are the thread size side?
What? You mean you don't like fiddling around with the little metal clips? Those things are awesome!
You're going to need some adapters bro. There are a TON of them out there. Worry about line size after you determine what threads/adapter fittings you're using. Easiest way I know is to find the part number for the OEM fitting and read the description. They usually have the thread pitch in the descriptions.
I'm guessing the steering rack threads look about 1/2" NPT. So you'd need a 1/2" NPT to -4 or -6 AN adapter. (DON'T FORGET to get PTFE lined hose for any hydraulic fluids.)
08zr1 (09-03-2021)
thing knower
I have all this give me an hour....
transmission adapters.. **** I can't remember which I used...
these were installed in the b&m cooler...
https://www.summitracing.com/parts/ear-at981668erl
these went in the transmission... they came with viton seals...
https://www.summitracing.com/parts/sum-220166b
need 90s for inlet and outletshttps://www.summitracing.com/parts/sum-220687b
and some an line...
https://www.summitracing.com/parts/sum-240610b
I used the b and m cooler mounted behind the drivers rear wheel...
https://www.summitracing.com/parts/BMM-70298
as for the power steering I would have to look in to the pressure the an fittings can handle....
hope this helps!
some of my install work...
trans fittings..
https://www.corvetteforum.com/forums...post1602278067
cooler mount
https://www.corvetteforum.com/forums...post1602955097
and some an line...
hope this helps!
trans fittings..
cooler mount
08zr1 (09-03-2021)
So I ended up just ordering a 2009 trans line and for the power steering fitting I ordered from a and a corvette I’m making a custom power steering cooler setup that I might add pics and stuff if someone is interested
drewz06 (09-03-2021)
