[ZR1] Passenger front sitting at least .5" lower than front right even with bolt full high
Hi guys, just got my 2010 ZR1 about 10 months ago. Car drives fine and always has. I took it for its first oil/fluid change today at a Corvette speciality shop here in CT. Both myself and they noticed that the passenger side was about .5"+ lower than the driver front. But stock bolts were even when they looked on the lift. They didn't notice any issues elsewhere. The car only has ~8,300 miles on it, and everything underneath, including the spring looked good as new.
To clarify - I am talking about tire to fender gap. Two fingers on drivers side, maybe 1 finger on passenger side.
They jacked up the stock bolt on the passenger side as high as it will go, but there is still a .5" difference between the two sides. They said maybe the spring just needs to get replaced. Any thoughts?
My initial thought was that the car was setup this way to compensate in track conditions for only a driver. But given they adjusted the stock bolts to now be uneven by essentially putting the passenger side up as high as possible and there is still a .5" difference, I am not so sure.
Thoughts?
Thoughts?
Welcome any thoughts though.
Yep, I ordered 2 sets from Corvette Central - the OEM replacements. So should be good. My rears are ok so I didn't order anything for them. But at least I'll have an extra set for the front. I have no desire to lower the car more than the stock bolts allow. Last thing I need is to deal with the front splitter or lower radiator support getting banged up.
