[ZR1] Small puff of smoke on cold start
I've seen videos of other ZR1s do this, is it normal? Admittedly the car hasn't been started in 2 weeks. And then you could see some small bits of smoke come out towards the end. It was about 50 degrees outside.
I cannot really tell from your video, it looks like grey smoke which I would not be concerned about; especially at 50 degrees ambient temp, however, if the smoke has a blue tinge to it, that could signify bad valve guide seals. A short, puff of blue smoke, on initial start up, is classic valve guide seal leaking evidence.
Landru (03-04-2023)
Don't worry about it. If its oil smoke, at least your guides are getting lube. Worst consequence would be eventually plugging cats/fouling O2 sensors. If either happens down the road (it'll be awhile), you'll have a definitive answer.
Puff was so slight actually had to view several times.
Since what I could see was a slight puff of gray betting it's merely condensation, especially in 50* temps.
As others stated IF it were blue it'd be a sign of oil burn, valve seals most likely culprit.
BTW tip next time returning from operation.
Spray inside tips w/ some EasyOff, let sit a few minutes & rinse w/ water.
Landru (03-04-2023)
