C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Axle Nut Torque Spec
Old 05-01-2024, 02:45 PM
Dj_or_dj
Dj_or_dj's Avatar
Originally Posted by ncnmra
I'll do the job in the next few days, but last night I went to check with a torque wrench set to 110ft-lbs. The driver's side was fine, but the passenger side moved about 1/4 turn before clicking in. I went for a drive and the clunk was completely gone, so I can safely say this was the issue, even at a low 110ft-lbs setting. It was like driving a totally different car, I didn't realize how much that clunk annoyed me.
@Dj_or_dj : Do you know if the spec changed for 2008+? I read somewhere that GM updated specs for that year. I also read that the TSB recommendation of 160lb-ft was on "wet" threads due to the Loctite.
Given that the issue was solved at 110lb-ft, I'm certainly leaning to less than 160. Last thing I want is a borked axle.
From what I understand,
Between 05 - 13 the part number stays the same and is interchangeable.
So if that is the case, I would assume the torque spec stays the same being the axle nut is the same size 33mm
Old 05-01-2024, 02:46 PM
Lights ZR1
Lights ZR1's Avatar
The axle nuts were changed at some point, from 33 mm to 34 mm. When I changed the originals on my 2010, it took a 33 mm socket, the new ones took a 34.
Old 05-01-2024, 02:48 PM
Texasthunder
Support Corvetteforum!
Texasthunder's Avatar
Do 150 and call it a day
Old 05-01-2024, 03:20 PM
Dj_or_dj
Dj_or_dj's Avatar
I just follow what the manual says for my year.
you can always ask the dealership what the torque spec is.
Old 05-03-2024, 08:19 AM
tommyc6z06
tommyc6z06's Avatar
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
also double nutted here...original 33mm reused, with new 34mm on top, 151ft.lbs. Done
