C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Tt Zo6?
Old Sep 20, 2005 | 06:55 PM
YUL LUZ's Avatar
YUL LUZ
Cruising
Default Tt Zo6?
What about a TT kit for the Z06? the compression is way to high but if you TT a vette, usually you go into the motor to rebuild/re-enforce anyways. Any thoughts?
Old Sep 21, 2005 | 01:47 AM
NOSjohn's Avatar
NOSjohn
There are TT kits out there for the vette. Both DIY and installation only. What are you asking? A kit can be put on a stock compression motor.
Old Sep 21, 2005 | 02:18 AM
YUL LUZ's Avatar
YUL LUZ
Cruising
How much would the stock ls7 block handle boost-wise? What do you think that you would have to replace in the block to run big boost? Just rods and pistons?
Is there a tt kit for the z06 like the PTK ?
Old Sep 21, 2005 | 10:29 PM
LSs1Power's Avatar
LSs1Power
If the stock pistons and Ti rods hold 650-750rwhp then u can always run Methanol injection to help you run 6-8psi on the stock C/R or even 10-12psi on Race gas when needed.
Old Nov 7, 2005 | 04:53 PM
Thrust NYC's Avatar
Thrust NYC
The hunger for more power never ends!
To Tt Zo6?
