Installed the nx 1 pc maf kit over the weekend. i did learn the hard way that the nitrous express wot switch will not work with the 06 because it only reads a rising voltage. nx swapped me out with a 2 stage progressive mini controller from fjo racing. wow! this thing is awesome! as far as the switches go, we installed everything in the glove box and ran the nitrous lines in the back where they can be tucked away if i want to take the bottle out. install was pretty clean after learning about the wot switch.
This kit seems to be working well. nitrous is the way to go!
Someone tell me how to post pics!
Dyno #'s
stock with lingenfelter air box - 347hp/344tq
with 100 shot nx - 436hp/496tq
Way to go.....You should really like the 1pc Maf kit....I guessing your are tapped into the falling voltage for your TPS The raising voltage cost me alot of time troubleshooting. Post some pics when you can
