Have been discussing the fuel system setup on a blown, C6. The owner says he cannot boost reference the Fp regulator, [AEROMOTIVE], as the fuel system will not operate, if the FP is pulled below 58psi.
He indicates the FP is set to 61, and that's the only way the system will continue to operate, at idle.[He also stated that the FP drops to 58 at 15# boost.]
NE1 explain this in a short ??
Also, where can I purchase some info on these OEM system[s]??
All I can tell you is that when I got a supercharger It came w/an additional high output fuel pump and a fuel regulator,known as the FMU.that's all I know,sorry.
