C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
180 shot?
Old Jul 16, 2006 | 11:19 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default 180 shot?
I have been checking out nitrous systems for the C6 and it seems that I see alot of them which show 80-100-150-180 shot capability. I know that the C5 systems usually showed 75-100-125-150. Is the larger engine capable of taking a 180 shot? I know that MOST recommended not going larger than a 150 on the LS1, has the max recommended shot increased on the LS2 due to better fuel pump, larger engine, etc. or is a 150 still the norm for the most it can take while keeping stock and tuning? Thanks for the input
Cajun
Old Jul 17, 2006 | 02:50 AM
C6 Vet's Avatar
C6 Vet
My personal limit is going to be a 150shot. I will have a good tune, race fuel, colder-plugs, and window switch.
Old Aug 9, 2006 | 09:54 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
A 150 is generally cosidered the safe max shot. Now if your willing to make sure your fuel system is up to snuff and your full tune is spot on a 200rwhp shot can be handle easily. I would, and do, run this 200 in a multi stage or progressively. I have hit the 200 on a stock block and currently am running a 180, and I run it very hard, no issues to date with approx 150 passes.
The multi stg and/or progressive hits will help break up the giant, all in one hit, torque spike. This is the real enemy of a stock long block, massive torque at low rpms. So split your shot up some and allow the stock block to live and you can still go way fast.
Robert
Old Aug 11, 2006 | 09:50 PM
0Cajun @ Edgyvette
Former Vendor
Robert
Good stuff, thanks Robert. Do you guys do installs? Thanks
Cajun
Old Aug 12, 2006 | 02:26 AM
Robert56@RNS
Collections Hold
Cajun
I do some for locals.
Robert
Old Aug 13, 2006 | 01:39 AM
Z-51 POWER's Avatar
Z-51 POWER
I am doing a 175hp shot and the C6 is running great, acutally thinking of going up to 200hp shot. I will keep you guys posted.
Regards,
Manuel
Old Aug 13, 2006 | 06:41 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
guess you guys are looking to kill your motors quick.
Old Aug 13, 2006 | 08:54 AM
dennis50nj's Avatar
dennis50nj
Regards,
Manuel
what kit and what kind off times
Old Aug 13, 2006 | 12:42 PM
Robert56@RNS
Collections Hold
Naw, not true at all, look at my post. There are many doing 150/180/200 and no issues. Now with that said, once you get above 180 on a stock long block unless it's progressive or multi staged, yes you may wear your engine a little faster. But remember, if everything is right on your only running the higher cylinder pressures for about 10 sec at a time. Going fast, whether a blower, turbo or nitrous there is allways a certain amount of risk, with none really being safer than the other.
Robert
Old Aug 13, 2006 | 12:44 PM
Z-51 POWER's Avatar
Z-51 POWER
The kit that I am using is sold by Nitrous Direct and times well I do not have a set of slicks to go to the track so I have not wasted my time...here in Puerto Rico we run in the street and a week ago I ran from a rolling start with an STI that does 10.8sec @ 128mph and I was in front by half a car length up to 5th. Hope this helps.
Regards,
Manuel
Old Aug 13, 2006 | 02:27 PM
dennis50nj's Avatar
dennis50nj
Regards,
Manuel
thanks Manuel any other mods
Old Aug 13, 2006 | 07:11 PM
Robert56@RNS
Collections Hold
Regards,
Manuel
Can't go wrong with Nitrous Direct, but I might be a little biased? Which kit did you get, NX or CF and wet or dry?
Robert
Old Aug 13, 2006 | 08:08 PM
Z-51 POWER's Avatar
Z-51 POWER
Yes;
160 degree thermostat
Haltech Intake
Custom Diablosport tuning
Borla Stinger exhaust
Custom Downpipes with no cats
LG Motorsports crank pulley kit
Nitrous Direct single shot kit
Skip Shift Eliminator
B&M Sport short shifter
Old Aug 13, 2006 | 08:10 PM
Z-51 POWER's Avatar
Z-51 POWER
Robert
I really do not know, plus I did not buy the bottle from them. I got it here locally...I have a 25lb chrome bottle!
Regards,
Manuel
Old Aug 14, 2006 | 01:08 AM
Robert56@RNS
Collections Hold
Regards,
Manuel
Cool, you have almost as much nitrous as me. I run dual 15lb'ers for a total of 30lbs.
Robert
To 180 shot?
