C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Procharger Issues
Old Aug 17, 2006 | 12:44 AM
Gagunga's Avatar
Gagunga
Why doesn't PROCHARGER deal with this?? This is a major design flaw. The corrections are clever, but for the 8-10K you spend on this, you shouldn't have to resort to improvisations to deal with it.
**** like this is another good example of how half-assed the aftermarket can be.
Shame on Procharger for creating so many headaches and problems.
Old Aug 17, 2006 | 02:11 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
This is just a continuation of what crap they produced for the C5's and if we can educate all of you new C6 owners go over into the C5 FI and there are lots of threads pertaining the ATI issues. This is why A&A/ECS made there own kits to support the ATI head units, oh both of these vendors now use other head units with there kits. I have an ATI DS1C, however I have the A&A setup I modded like big bollas did on his C5. This is pretty much how the A&A/ECS kits are coming out now with the spacing to assist with the cooling issues.
The best fix if you want a ATI setup is to do the big bollas mod, or buy the newly released setups from A&A/ECS and you will not have to do that mod. When I did the install on my C5 I knew about this issue as I did the research of what all you on this board are finding out about ATI, there head units are great, the customer service and the complete layout of there kits just plain su$k.
BTW my little ole 346 puts down good numbers and has never had a cooling issue do to the mod I did and the DeWitts radiator. My reason for posting is so all those thinking of purchasing the ATI unit to be ready to fix the FMIC issue upon install and you will have a great setup, I really like mine
Old Aug 17, 2006 | 06:32 PM
Gagunga's Avatar
Gagunga
Great post - and I'm in So Cal, so working with A&A is easy
Old Aug 22, 2006 | 04:56 PM
Laguna Blu's Avatar
Laguna Blu
Originally Posted by drewcorvette
Heat is a major issue and I don't even drive the car that hard most of the time. I was driving around this weekend normally and oil temp jumped to 250, I immediately shut the car off and opened the hood outside temp was only around 89. My oil temps are ranging from 217-250 its astonishing how my oil temps vary so much. Hopefully vettedoctors can work some magic and fix the heat issue. So far they have no suggestions.
Damn a/c shuts off to when the car gets hot, especially sucks in traffic when its 95 and humid out/ my car has become a sweat box at times.
How did you make out with the oil temp issue? I just ordered a DeWitts radiator, which I'm hoping will help keep things a bit cooler once the Procharger is in. Vette Doctors is doing all of the work so hopefully they are up to speed on the heat related issues.
Old Aug 22, 2006 | 06:59 PM
Romeo90626's Avatar
Romeo90626
Default GM A/C Fix
GM put too much refrigerant at the factory. Take it to your dealer and he'll remove some of the refrigerant charge. Fixes the problem.
Romeo
Old Aug 22, 2006 | 07:18 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Romeo
I agree, had the same problem after the D1SC was installed, took out 1/2lb of freon and bingo, AC works perfectly.
Old Aug 22, 2006 | 10:19 PM
Laguna Blu's Avatar
Laguna Blu
This is the first time that I ever heard that by removing refrigerant the A/C will work properly.
Old Aug 22, 2006 | 10:45 PM
saplumr's Avatar
saplumr
Some came from the factory overcharged by .4 pounds, and it DOES make a difference.
Old Aug 23, 2006 | 08:51 AM
Mr.Big's Avatar
Mr.Big
Take the advice...There is a T.S.B. from G.M. on this... It will allow you to have A/C that works again...
Jeremy
