I'm wanting to install my TNT Nitrous on my 2006, Z06. It came off my 2000, C5. I was using the MSD window switch, it was getting it's signal for the tach from the computer. Does anyone know which wire to use on the 2006 from the computer?
Joe
Integrated wide-open-throttle detection
Each channel has a multi-gear lock-out setting
User configurable for rising or falling TPS signal
Supports low voltage tach signals as low as 3 volts
Works with irregular tach signals such as V10 and 3cyl
Push-button programming with integrated LED digital display
Dual window switch
Compact rugged, waterproof design
Part Number Description Price
NO-00-7121 Digital Dual Window Switch $ 129.00
any info or pic on the tach wire for a window swicth
For a regular C6, the tach wire is the white wire (pin 48 I think) on the ECM, not sure if it's the same on the Z, but guessing it is.
Also, the WOT throttle position switch signal should tap into the purple wire (don't know pin position), but can trace it to the throttle body. It goes 5V positive at WOT.
