C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Crank pinning..
Old Oct 14, 2006 | 09:43 PM
SpiralCoupe's Avatar
SpiralCoupe
Default Crank pinning..
Is it necessary to pin the crank when installing a Procharger D1SC?
Old Oct 14, 2006 | 09:47 PM
saplumr's Avatar
saplumr
The ProCharger comes supplied with the pin.
Old Oct 14, 2006 | 10:18 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Yes it is. I wouldn't want to go without it.
Old Oct 15, 2006 | 02:46 AM
Brabus2's Avatar
Brabus2
The LS2 harmonic balancer is just held in by an interference fit and the retaining bolt tightening torque, with the ProCharger's added power at the crank and higher loads on the pulley can make the balancer spin right off the front of the crank.
Old Oct 15, 2006 | 10:59 AM
vertC6's Avatar
vertC6
Its not so much spin off the crank is that it will spin on the crank, also very bad.
Old Dec 11, 2006 | 11:09 PM
briann510's Avatar
briann510
Is it for all LSX engines also? Or are the LS6 or LS7 not needed to pin?
Old Dec 12, 2006 | 02:08 AM
My2Dogs's Avatar
My2Dogs
I told you the crank needed to be pinned. Didn't believe me , huh ?
Old Dec 12, 2006 | 12:42 PM
Mr.Big's Avatar
Mr.Big
As stated it's a MUST!!!
Old Dec 12, 2006 | 01:58 PM
EuroRod's Avatar
EuroRod
It's really not that hard to do. Getting everything out of the way to accomplish the task is the major part of the work. That, and getting the %^$#!?*# crank bolt loose! That part is a PITA!
Old Dec 12, 2006 | 11:35 PM
SpiralCoupe
Man, this was an old post. Thanks for the replies and thanks to everyone here I made sure it was done.
Old Dec 13, 2006 | 07:54 PM
snappy28's Avatar
snappy28
Cruise-In VIII Veteran
Here is a pic of my crank keyed on my LS1 that I had rebuilt. On this particular setup I was running a Vortech T trim.
To Crank pinning..
