C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
APS Upgrade
Old Nov 18, 2006 | 11:25 PM
Hybrid901's Avatar
Hybrid901
Default APS Upgrade
What is the largest turbos that will fit on the APS C6 manifolds? Do you need to upgrade the wastegates to run 15psi or can you just adjust the accuator arm?
Josh
Old Nov 19, 2006 | 12:11 AM
Phate's Avatar
Phate
I think that the largest turbos that will fit the manifolds themselves are on there. I haven't mounted up my kit yet, but I bet it is pretty cramped.
However, it might be possible to fit a larger cartridge in the existing housings by having them machined...I took my manifolds/turbos apart today (preparing for coating and possibly extrude honing) and spent some time looking at the exhaust housings. It looked to me like there might be enough thickness in the housings to fit something bigger, but I am by no means a pro.
In regards to the wastegates...an EBC should be all that you need for 15psi, although I do know that Tom @ NLP was working on fitting some billet actuators to replace the stockers, he has a TON of experience with this stuff...give him a call.
Old Nov 19, 2006 | 02:27 AM
Hybrid901's Avatar
Hybrid901
The kit is currently on a 06 A6 and running of the wastegate we are seeing 5psi. With the greddy electronic boost controller we are only seeing 6.5 psi. The car is getting a 402 next week.
Old Nov 19, 2006 | 01:16 PM
Phate's Avatar
Phate
Sounds like the EBC might not be setup correctly. There are usually a couple of dip switches (older models) or electronic options (newer models) that allow you to configure the controller for twins or a single.
If it is a newer model make sure that you have the overboost setting where you want it, or it will limit boost.
Old Nov 19, 2006 | 05:43 PM
APS's Avatar
0APS
Former Vendor
Josh
Josh, The C6 twin turbo system is delivered with 7.5 PSI boost control actuators that can be adjusted to around 9 PSI boost pressure. if you want run 15 psi then you would need to fit higher pressure boost control actuators. Obviously you would need a built forged engine with a staic comp ratio of approx 9:1 to safely run high boost pressure, hope that helps.
Peter
Old Nov 19, 2006 | 09:44 PM
Hybrid901's Avatar
Hybrid901
Thanks Peter, the motor is already taken care of with a 8:8:1 402. Do you guys sell the actuators or will any mitsu actuators work?
To APS Upgrade
