Pics of progress
Nov 26, 2006 | 05:28 AM
Pics of progress
Nov 26, 2006 | 10:52 AM
What size Reichard pulley did you go with? Looks great, don't forget to make the adjustment where the IC pipe comes in at the bottom, very important.
Nov 26, 2006 | 02:38 PM
Quote:
It's a 3.90" pulley and I am actually getting it done at HPE so I am sure they will do whatever they need to. But thanks for the heads up.
Nov 26, 2006 | 03:06 PM
Nov 26, 2006 | 04:08 PM
St. Jude Donor '06-'07-'08
Looks great!
Keep us posted
John
Nov 26, 2006 | 04:50 PM
Wow a 3.90 pulley ,how much boost is that going to put you at?
I am at 10lbs with a 4.25
Nov 26, 2006 | 11:52 PM
That's weird. We were told that the 3.90 makes 10psi.
Nov 27, 2006 | 12:27 AM
no dOubt mine is a 5 incher!!!!
Nov 27, 2006 | 10:56 AM
On a Stock Car (100% OEM stock)
With a P1-SC-1 (Stock Blower)
4.63" = 6.0psi
4.50" = 7.0psi
4.38" = 8.0psi
4.25" = 9.0psi
4.10" = 10.2psi
Hope that helps,
EA
Nov 27, 2006 | 11:50 AM
It depends is it a D-1 or P-1, a P-1 will make 10-11 but the D-1 will make 12-13psi.
Nov 28, 2006 | 12:28 AM
Mike...good luck with the results buddy.
