C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
T-Stat Change
Old Dec 1, 2006 | 09:46 PM
snappy28's Avatar
snappy28
Cruise-In VIII Veteran
Default T-Stat Change
Should I swap my stock t-stat out for a 160? I am having a Maggie installed soon with a dyno tune. Everything else is stock. Other than a cooler running engine what other benefits does it provide?
Old Dec 1, 2006 | 09:59 PM
excessive81's Avatar
excessive81
that is the reason and with fi you will need all you can get!
Old Dec 2, 2006 | 06:48 AM
EuroRod's Avatar
EuroRod
With the Maggie, the intercooler is a water/air unit that sits under the supercharger. There is no front mounted unit (ala ProCharger) to impare airflow to the radiator. I haven't heard of any cooling issues with the Maggie, but I think a 160* t'stat would be a good idea, along with a recalibration of the fans perameters when you get your tune. Good luck.
To T-Stat Change
