C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Average coolant temps w/ ATI
Old Dec 16, 2006 | 12:56 AM
ToSlowForU's Avatar
ToSlowForU
Default Average coolant temps w/ ATI
I am running anywhere from 199-215 depending on driving conditions. Is this what all you guys are seeing? This is after driving all day in Houston. Temps today were upper 70's with 82% humidity.
Old Dec 16, 2006 | 06:16 AM
excessive81's Avatar
excessive81
it has been 50-60 here latly and i am seeing 185-195. opps that is oil temps
Old Dec 16, 2006 | 06:47 AM
EuroRod's Avatar
EuroRod
FYI. Here's my setup: ProCharger, Meziere electric water pump, Ron Davis 57mm radiator with internal oil cooler, 160* t'stat, DynaTech headers, cats, and X pipe, and forward relocated intercooler. Yesterday, 65*: At 70 mph cruise, coolantn temp was 178*, oil temp was 188*. In traffic: coolant was 210*, oil temp was 216*. The fan cycles on at 216*, which I think is too high. I will be getting a dyno tune in Janurary, and I will lower the fan cycling temp ranges. I want a 200* max temp before the fans cycle.
Old Dec 16, 2006 | 10:20 AM
saplumr's Avatar
saplumr
About 210-220 on 85-95 degree days.
Old Dec 16, 2006 | 01:55 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by big bollas
ToSlow, if your temps are running that high at the temps we are having right now ,they must have not done my intercooler mod and you are not getting any cool flowing air to the radiator.
Look at your intercooler and see if it has a gap on the backside by the A/c condensor on theb bottom by the air dam.
If you dont have a gap you need to look for my post so that you can do the "BB Intercooler Mod".
My temps are sticing around 176-190 at the highest with the AC!
I will be out and about today in the Houston area, give me a buzz if you need more info.
I will PM you my number
Air gap is critical to proper cooling of your engine as well as IAT's. Here in South Texas our summers are brutal. Without the mod BB speaks of, chances are good that you will be running too hot in the summer.
Scotty
Old Dec 16, 2006 | 04:10 PM
big bollas's Avatar
big bollas
Just got back from MTI and my highest temp was 187 down Westhimer
Old Dec 16, 2006 | 05:15 PM
excessive81
alright i paid attention to the coolent temps and mine mirrored the oil. 185 cruising and 195 or so setting in traffic. i think the hood helps as i ran cooler before the s/c
Old Dec 29, 2006 | 11:58 PM
lockshed's Avatar
lockshed
I constantly monitor my coolant temps. I run about 198 even in 58 degree weather and that is cruising at 70-75 mph. If their is a slight incline on the freeway, the temp can go up to 207 or so, even in 58 degree weather, and on a decline can go a little lower than 198. In the summer, it is plus or minus a few at cruising at decent speeds, but in traffic in the hot 100 degree summer, I can hit the 220's once in a while, and the AC becomes intermittent. I definitely need to do Big Bollas mod!!!!
Old Dec 30, 2006 | 12:09 AM
Mr.Big's Avatar
Mr.Big
185-200 depending on the driving variables, i.e. 5 o'clock traffic or crusing...
Old Dec 30, 2006 | 12:11 AM
saplumr's Avatar
saplumr
I see you have an 05. If you have intermittent AC problems, have you had refrigerant adjusted as required by service bulletin? I passed my AC problem off as a casualty of supercharger until my servicing dealer performed required work. It now is freezout even in 100 degree days.
Old Dec 30, 2006 | 09:12 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
, around the same numbers down here is SE FL
Old Dec 30, 2006 | 06:28 PM
07MontRedcp's Avatar
07MontRedcp
You might also need to remove a little freon if that's a high pressure sensor trip on the ac compressor.
BJK
Old Dec 30, 2006 | 07:55 PM
Mr.Big's Avatar
Mr.Big
BJK
Correct... Many, MANY of us had this issue... Take out some freon and you'll be amazed...
Old Dec 30, 2006 | 08:35 PM
schilitj's Avatar
schilitj
I took this suggestion this summer and let 1/2-1lb of freon out of the compressor and voila', no more AC issues.
To Average coolant temps w/ ATI
