C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Turbo Boost Controller question
Old Jan 8, 2007 | 09:10 PM
c5_from_jc's Avatar
c5_from_jc
Default Turbo Boost Controller question
How low can you turn down the boost in a turbo system if you have a boost controller? The reason I am asking is for a street application where traction is an issue, can you virtually turn off all boost in first gear?
Old Jan 8, 2007 | 10:54 PM
drochau's Avatar
drochau
No, the boost controller can't go any lower than the wastegate spring.
Old Jan 8, 2007 | 11:47 PM
Blocktrdr's Avatar
Blocktrdr
Yes you can. There are electronic boost controllers that can both take away boost and add it. You will have to prepare with tuning though. The common way is with a speed density tune.
Old Jan 9, 2007 | 08:20 AM
onfire's Avatar
onfire
You can't take away more than the wastegate spring. If it's a 10lb spring a controller can take you down to 10psi but not under 10psi.
Old Jan 9, 2007 | 09:11 AM
Blocktrdr's Avatar
Blocktrdr
I guess I should add that it takes a decrease solenoid and a dual port wastegate to do. It's not as easy as just turning the boost down on a standard system. Hope that clears up the confusion.
Old Jan 10, 2007 | 01:47 PM
drochau's Avatar
drochau
Please explain how this works as I'm not familiar with any boost referenced wastegate (in other words non-compressed gas actuated) that can produce enough pressure differential to open a wastegate at a lower psi than the spring is rated for.
Old Jan 10, 2007 | 11:35 PM
Blocktrdr's Avatar
Blocktrdr
Obviously you need an air supply. However, I missed the part in the original post about it being for the street. This is not real feasible for the street. It would be helpful in straightline racing where you might want a wide variance in boost control.
To Turbo Boost Controller question
