C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Do I need a 100mm MAF
Old Jan 21, 2007 | 08:13 PM
T-BONE05's Avatar
T-BONE05
Default Do I need a 100mm MAF
The installation of my A&A kit starts on Thursday (1/25). What are the advatages of using the LPE 100mm MAF versus the stock.
I'd really appreciate opinions of those with the 100mm, especially if they are using them in a FI application.
Thanks in advance
Todd
Old Jan 21, 2007 | 08:48 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I have one on My vette along with My Maggie!!
Check out pics in "My corvette photos"{under my avitar}
I think it helps !
Old Jan 21, 2007 | 09:41 PM
FunCool's Avatar
FunCool
I think it helps !
Where did you get it from? I have LPE 100mm maf and it does not look like that!
Old Jan 21, 2007 | 10:41 PM
1bdasvt's Avatar
1bdasvt
Got it from LPE direct!!
Old Jan 21, 2007 | 11:14 PM
FunCool's Avatar
FunCool
Thanks! what does it come with?
Old Jan 21, 2007 | 11:30 PM
1bdasvt's Avatar
1bdasvt
Just the MAF tube, wire harness,and I think the silicone boot!
Hope that helps!!{don't remember the price,think around $400.00?}
Talk to Kevin Jefferies,He's a great guy!
Old Jan 22, 2007 | 08:54 AM
Mr.Big's Avatar
Mr.Big
No, you do not need one... Most do not run it, since it isn't needed...
Old Jan 22, 2007 | 02:24 PM
excessive81's Avatar
excessive81
air being forced in not sucked so not needed
Old Jan 22, 2007 | 10:38 PM
C6dude's Avatar
C6dude
My buddies Shane and Jeremy , I'm going to have to dis-agree with you on this one.
The 100mm MAF will yield an improvement on a modded car. The more power your engine has, the more it yields. On a stock car , it's not worth the money.
HP gains will be very minimal if any. ON a modded car pushing high HP and a lot of air,it's a different story.
Whether it's FI or NA, the stock one starts to become a bottle neck.The 100mm unit flows more air all across the board.
I tried to find a dyno figure with a vette, to no avail.
I did find this one though:
Heres a link of a guy in a T/A with a 100mm unit.
Scroll down and look at the second to the last dyno chart .
It shows:
a base run
a run with a 100mm unit
a run with blower hat removed
http://www.exoticperformanceplus.com...Car.php?car=27
Old Jan 22, 2007 | 11:05 PM
excessive81
yes perry you do need one. with more cubes and high boost it will help. with a meger stock ls2 and 5 psi of boost i dont think you would see much inprovment....could be wrong wouldn't be the first lol
Old Jan 22, 2007 | 11:08 PM
1bdasvt's Avatar
1bdasvt
C6Dude,Your vette looks KILLER!!!!!!!!{nice choice of color too! }
Old Jan 23, 2007 | 12:07 AM
2JZFAN's Avatar
2JZFAN
does the 100mm sample any different? I mean the stock is what 90mm right? I just don't see the HP per dollar value.. there are much more important things to do with the cash at almost any level of performance.. Honestly I'd rather get an electric water pump then an MAF for it's benefits versus the minor HP increase of the MAF. Has anyone else done any comparisons?
Old Jan 23, 2007 | 01:00 AM
C6dude's Avatar
C6dude
Thanks, 1bdasvt
You have a Nice ride yourself..
I took the values from my OEM MAF tables from my HP Tuners software and put them side by side with the LPE MAF tables that I had to recalibrate to.
If you notice the LPE MAF at 10600Hz flows the same as the OEM one at 12200HZ.
At WOT your car is running off of your VE tables not your MAF/PE tables. So the fact that the computer sees it as flowing 511.99 G/S from 10,600Hz to 12,200Hz doesn't matter. You tune your VE tables for the extra air flow and add the fuel needed while monitoring your wide band O2.
Here's the table comparison:
Old Jan 27, 2007 | 11:49 PM
Mr.Big's Avatar
Mr.Big
Perry,
I saw only 2 rwhp on back to back pulls with tuning changes for the new 100mm maf, same A/F i have 2rwhp differences between pulls with the same maf... Not worth the $300 imho... bollas seems to like his stock one as well...
But these are just my findings
p.s. I'm still waiting for your products to hit the market!!!!!!!!!!!!!
Old Jan 29, 2007 | 06:44 AM
C6Rluvur's Avatar
C6Rluvur
Originally Posted by Mr.Big
Perry,
I believe you, but maybe Halltech, is using a different dyno, he's claiming 4-5 rwhp and 8.8 rwto on a ported (I believe it's 100mm he wouldn't tell me)Z06 throttle body/maff mounted to a NA LS7...You think there's any truth to this or more salesman hype?
I'm asking cause I was interested in this very same subject, on my NA C6 LS2.
Jim, wrote me back saying the new C6 coming out in 2008 will supposedly be using an all new bigger throttle body/maf accounting for part of the rumored 425-450 hp C7?? He also said it wouldn't be interchangable on any other C6 from 05-07 because of different electronics to maff...
Any thoughts would be appreciated
Old Jan 31, 2007 | 12:38 AM
1bdasvt's Avatar
1bdasvt
Old Apr 4, 2007 | 12:09 PM
gojo's Avatar
gojo
Lingenfelter will tell you that their 100mm MAF is not any better until after 600hp.
To Do I need a 100mm MAF
