C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
The BIGGEST DYNO NUMBERS......
Old Mar 3, 2007 | 09:45 PM
JJSC6's Avatar
JJSC6
Default The BIGGEST DYNO NUMBERS......
Hey guys,
I had a question about whom is/has made the biggest power/torque RWHP/RWTQ per FI "STREET/LIGHT TRACK application" verifiable with an actual dyno graph that someone has seen or one that has been posted.
What have you seen for the "biggest" RWHP/RWTQ on A C5/C6 Corvette setup for both street/track use (something that is actually driven on pump gas mainly, perhaps with some octane assistance via methanol, Torco, etc.)???
Sample FI Categories:
A. Single Turbo
B. Twin Turbo
C. Quad Turbo
D.Roots Style Blower
E. Screw-Type Blower
F.Centrifugal Blower
G.Twin Centrifugal Blower
H. Compounding
I. What ever else???
What are the "BIG" numbers on the C5/C6 platform RWHP/RWTQ that people have seen...and on what brand of dyno????
I am curious, because I am a power "pig" (can't get enough of it...it seems), BUT more because I am curious to see what people have done
on this platform.
So what have you seen????
It can be stock or modified.
Old Mar 4, 2007 | 05:17 AM
Insom's Avatar
Insom
i think the stock bottom end MTI procharged ls2's are probably up here. 700rwhp.. i just don't like the powerband on a procharger
Old Mar 4, 2007 | 09:16 AM
Max@Cartek's Avatar
Max@Cartek
You're probalby going to get quite a wide range of responses as to what is streatable.
I guess I'll post up the first link :
http://forums.corvetteforum.com/show....php?t=1623992
Automatic on pump gas. This same setup in a stick would dyno quite a bit higher. This car is extremely streatable, but bad for your health .
Max
Old Mar 4, 2007 | 02:02 PM
JJSC6's Avatar
JJSC6
Max
Thanks Max!!! Nice build.
Old Mar 4, 2007 | 02:03 PM
JJSC6's Avatar
JJSC6
So, what do you like the powerband on?
I know, that 700 RWHP on a stock bottom end is psycho, but cool!!!
Old Mar 4, 2007 | 07:00 PM
Max@Cartek's Avatar
Max@Cartek
No prob. and thank you.
Old Mar 5, 2007 | 05:58 PM
ToSlowForU's Avatar
ToSlowForU
I have the D1 procharger set up w/ Kooks 1 7/8" headers, 2.5" x-pipe with cats HPE S cam and a meth inj. kit and I drive the car ALL the time. Pump gas and nothing else. My car goes on road trips and gets 30-32 mpg and does this.
[IMG][/IMG]
Old Mar 5, 2007 | 05:59 PM
JJSC6's Avatar
JJSC6
[IMG][/IMG]
Heh heh, that's prety cool for an everyday car!!!!
Anyone else???
Old Mar 6, 2007 | 11:30 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Anyone else???
That's pretty common now a days JJ, our 346 Paxton pkg makes roughly 750rwhp with stock heads, and over 800 with Trick flows through stock mufflers. You would never know it made that kind of power even if you went for a ride in it, if the owner didn't lean into it.
I think at this point all the major tuners have proven that they can make more power than the drive train can handle and still be very streetable with great gas mileage.
Old Mar 6, 2007 | 12:01 PM
TLewis4095's Avatar
TLewis4095
Old Mar 7, 2007 | 11:36 PM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
In my opinion, if you can't make 700 rwhp with stock shortblock and stock heads, you have a problem.
Chuck @ HPE
281-448-1300
Old Mar 8, 2007 | 02:21 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Jason, I saw this attached to your own car....with a restrictor.
Old Mar 8, 2007 | 02:45 AM
07MontRedcp's Avatar
07MontRedcp
[IMG][/IMG]
Nice dyno numbers. You need to update your sig for the new cam.
Are you still running 12 PSI?
BJK
Old Mar 8, 2007 | 07:26 PM
JJSC6's Avatar
JJSC6
Default Yee Haw!!!!!
Heh heh!!! Love it!!
Thanks Charlie!!!
Nice numbers for a restricted F/I application!!!
I wonder what happens when one takes the restrictor plate out????
Thanks again!!
Old Mar 8, 2007 | 10:37 PM
F1_SS's Avatar
F1_SS
[IMG][/IMG]
Was that on a stock bottom end?
How many PSI?
Specs on the S cam?
Was it tuned for meth or meth just for safety?
Why did you go 2.5" X pipe and why cats?
Old Mar 12, 2007 | 10:41 PM
corvetterich's Avatar
corvetterich
Great numbers, But is that safe with a stock bottom end, I assume its a stock bottom end.. And does anyone know what is a safe HP level for a stock C6 w/6m...before reliability suffers..Thanks
Old Mar 12, 2007 | 10:54 PM
JJSC6's Avatar
JJSC6
That's a forged "bottom end" on mine.
To The BIGGEST DYNO NUMBERS......
Old Mar 14, 2007 | 02:59 AM
Invisiguard's Avatar
Invisiguard
what did Brabus finally put down with the new motor??
Old Mar 14, 2007 | 11:43 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
I've got several stock bottom end D1SC cars putting down over 700 rwhp. With a conservative tune up, like they have, they seem to be holding together! But the rods might say see ya later before too long! If you want max dependability, obviously it's best to build a forged shortblock.. But if you can't afford it up front, it's not going to hurt you to run the blower on the stock motor... You can always be "real" safe and run a larger pulley on the blower to decrease boost/power until you have a forged shortblock for it.
Chuck @ HPE
281-448-1300
Old Mar 14, 2007 | 06:39 PM
corvetterich
Sales@HPE, Thanks for the info.. Question, are any of the cars using the D1SC and putting out 700HP C6's...
