C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost-a-pump question
Old Mar 29, 2007 | 10:29 PM
EuroRod's Avatar
EuroRod
Default Boost-a-pump question
Has anyone experience installing a Kenne Bell Boost-a-pump on their ProCharged C6? I received mine today, and any helpful install hints will be appreciated, such as, what wires are involved. Also, any suggestions on what setting to begin with, before driving to the tuner. Thanks.
Old Mar 29, 2007 | 11:30 PM
Brabus2's Avatar
Brabus2
http://www.cajundude.com/bap.htm
My installer/tuner had mine set at max!
Old Mar 30, 2007 | 02:43 AM
C6dude's Avatar
C6dude
That's what I do with all my BAP installs also, and it's a good idea.
All you have to do to set it to max permanently and eliminate the controller is to get an RCA plug, short the contacts together and then plug it in where the controller wire went. Or you can cut the controller wire about 2 inches from the end and solder the wires together.
Now, when it activated by the boost switch it will be always be at max amperage.
Old Mar 30, 2007 | 07:17 AM
EuroRod's Avatar
EuroRod
Thanks, guys. Knew I could count on the Forum experts for a great answer!
Old Apr 2, 2007 | 02:01 PM
EPP's Avatar
0EPP
Former Vendor
These pic's may help you out. Bob
Old Apr 2, 2007 | 04:10 PM
Ultimate CC's Avatar
Ultimate CC
I run the BAP on our shop cobra, works very well...
To Boost-a-pump question
