C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
acceleration
Old May 4, 2007 | 07:06 PM
vettelover54's Avatar
vettelover54
5th Gear
Default acceleration
hey guys
quick question for all you turbocharged vette owners out there. I know that many people buy turbos for the horespower gains, but do turbos actually have a huge impact on acceleration?
for example on a stock A6 c6, could a turbo push it to 60 in under 4?
maybe this question seems dumb or newbish to you guys and i apologize
Old May 4, 2007 | 10:43 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I think it would depend on how it was set-up.
My Maggie,I'm sure can get to 60 in 4 or less,and I know TT'S can do the same!!
Old May 4, 2007 | 11:37 PM
Max@Cartek's Avatar
Max@Cartek
Originally Posted by vettelover54
hey guys
They will definitely accelerate you harder from a dig, well assuming you don't buy a turbo so big you need a two-step to get it to spool off the line, but I doubt that will be the case.
Old May 4, 2007 | 11:47 PM
excessive81's Avatar
excessive81
it is after 60 where it makes a big diffrence. car pulls line a raped ape to 150+
Old May 5, 2007 | 12:17 AM
Brabus2's Avatar
Brabus2
hey guys
I would say turbos have a HUGE impact on acceleration when done right, and Max @ Cartek brings up one of the most critical part of turbocharging any engine; turbo sizing to keep the power and fun throughout the powerband!
Acheiving sub-4 sec. to 60 is all about traction management with any FI setup on our cars, but turbos do have an advantage with the use of an EBC; features including - timer function to allow time-based boost control, for better control of aggressive turbo systems, adjustable boost ramps to improve launch control logic and re-spaced ramps for more linear boost control are used by drag racers in getting out of the hole.
Old May 5, 2007 | 12:25 AM
valdeztke's Avatar
valdeztke
You can hit 0-60 on the speedo almost instantly. Tires light up and spin to 100mph in less than 5 seconds - car goes no where though. But the smoke the tires make sure can be fun....
Old May 5, 2007 | 09:23 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
Old May 5, 2007 | 02:49 PM
vettelover54
5th Gear
haha, well what about a supercharger or is that basically the same as a turbo.
the zo6 manages sub 4 times it is surprising that the FI can't achieve this feat w/o too much tire spin.
Old May 5, 2007 | 07:07 PM
BlackMagicC5's Avatar
BlackMagicC5
If your mainly concerned with 0-60 times, and speeds under and up to the typical speed limits, I wouldn't recommend forced induction. I'd recommend better tires, gears, boltons, ect. Traction can be difficult to manage under 60mph in forced induction cars.
Old May 5, 2007 | 07:42 PM
C6 Twin Turbo's Avatar
C6 Twin Turbo
Each person must decide what they want there car to do.
Then build it to do it!
Old May 6, 2007 | 06:27 PM
C6 Twin Turbo
I ran my car with a gtech today to answer your question. I have an A6 C6 with APS twins and APS exhaust. I had my DR tires on the car. I got decent traction and made 3 0-60 runs. I ran a 3.32 a 3.42 and a 3.11 The best 60ft was 1.765 and 3.11 sec 0-60 speed. I do think you could do better then these times. I think I could have loaded up the car a hair more.
Old May 7, 2007 | 06:55 AM
JFijolek's Avatar
JFijolek
YOU BET IT CAN!
Old May 8, 2007 | 12:45 AM
DSOMC6's Avatar
DSOMC6
The 30-120mph pulls (2nd gear from a roll in an A6) is awesome with a little better traction!
Good numbers! You have darn near the same set-up as I do. I knew I had to be getting pretty quick times.
Old May 8, 2007 | 07:16 AM
EuroRod's Avatar
EuroRod
It's all a matter of traction. I believe that a pure stock C6 will run a sub-4 sec zero to 60 with DR's and a good, sticky track.
To acceleration
