C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
gt35r?
Old May 31, 2007 | 01:43 PM
dstage's Avatar
dstage
Default gt35r?
Where is the best place to purchase two GT35R Turbos?
Old May 31, 2007 | 02:09 PM
Brabus2's Avatar
Brabus2
Talk to Linda at ATP or Rick at Exile.
http://www.atpturbo.com/
http://www.exileturbo.com/
Old May 31, 2007 | 02:34 PM
turbo_tom's Avatar
turbo_tom
Originally Posted by Vindication
Hey Richard. Why don't we do this? Why don't I sell you the 35's from my kit and I'll go with 42s? haha
The powerband I've seen on any car with a GT42R absolutely sucks. 35's are the way to go, IMO.
Old May 31, 2007 | 03:23 PM
Brabus2's Avatar
Brabus2
The GT3082R would be a nice upgrade to the 3076R, however it's a T3 flange setup and can be purchased internal gated with an option for the TO4E compact compressor housing which I believe would be the only frame to fit the tight areas in the C6.
This turbo is the same exact GT35/40 compressor wheel found on the 3582R , but runs the smaller 60mm w/84 trim turbine wheel from the GT30R. Rated at 65lbs/min.
Mark, hope to see and Scott at the shop tomorrow....we'll be testing out the dual ports, keep your fingers cross!
Old May 31, 2007 | 06:22 PM
Vindication's Avatar
Vindication
GT42s on a 427 motor? Could be overkill? Could be interesting? Someone crazy out there is going to try it no doubt.
Old May 31, 2007 | 06:25 PM
Vindication
Originally Posted by Brabus2
The GT3082R would be a nice upgrade to the 3076R, however it's a T3 flange setup and can be purchased internally gated with an option for the TO4E compact compressor housing which I believe would be the only one to fit the tight areas in the C6.
I will be there Richard. Everyone wants to see you happy with this car. I'll definately keep my fingers crossed.
Old Jun 1, 2007 | 07:50 AM
chuntington101's Avatar
chuntington101
its a really good setup!Corvette4ever on here runs twin 42s on his C5. not dynoed last time i saw the car but should make an easy 1000bhp on pump. hes running a C5R block.
wonder if the GT37s would fit???? these would bridge the gap between the 35s and the 42s
thanks Chris.
Old Jun 1, 2007 | 03:41 PM
turbo_tom's Avatar
turbo_tom
...Chris.
When does he make full boost? Does anyone have a link to his dyno sheet? I'd like to see what that setup looks like on a V8, considering all the 4cyl -6 cyl applications make full power wayyy too high in the rpm range for my taste... I saw a Supra with a 42R that made around 800 peak WHP... at about 800 rpms before redline.
Old Jun 2, 2007 | 01:04 AM
backchannel's Avatar
backchannel
thanks Chris.
check out the specs.- gt 37 has about 10% less flow than gt 35
Old Jun 2, 2007 | 07:29 AM
chuntington101
i think he is making full boost about 4k. PM him, sure he will be more than willing to spill the beans
Chris.
To gt35r?
