C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Vortech concerns.
Old Jun 30, 2007 | 07:24 PM
ayousef's Avatar
ayousef
Default Vortech concerns.
Vortech V-2 SQ S-Trim Supercharger
The new generation supercharger included in most Vortech street supercharging systems
* Helical cut gear profile with SQ technology
* Near silent operation
* Fits engines up to 680 horsepower
* Maximum airflow: 1,000 CFM *
* Maximum boost pressure: 20 PSI *
* Maximum impeller speed: 50,000 RPM
* Adiabatic efficiency: 72% **
* Available with straight or curved discharge and clockwise or counterclockwise rotation
Does this mean that the supercharger will only be able to handle boost until the engine reaches 680 HP? Sorry im not really good with this!
Also how loud/quite is the SQ system, is there anything you could modify in the system to get the "fluttering" sound you usually hear from a turbo-charged car? not the BOV "woosh".
Old Jun 30, 2007 | 08:21 PM
saplumr's Avatar
saplumr
The super quiet (SQ) Vortech I had on another vehicle was quiet as far as blower sound, but it made an ungodly rattling sound. I pulled the head unit and sent back for repairs. Put it back on...same thing, so I got rid of it. The airflow you have listed is will definitely restrict power output.
Old Jun 30, 2007 | 08:32 PM
ayousef's Avatar
ayousef
thx for the reply, I read this somewhere, is this common?
yeah it sure does restrict output, but does this mean the blower will only be able to run on a car below or equal to 680 HP? that's weird =S
Old Jun 30, 2007 | 10:57 PM
NemesisC5's Avatar
NemesisC5
The Vortech V2 SQ head units are among, if not THE quietest head unit on the market. They do make other models like the V1 which are somewhat noisy, like some others on the market. I have the V2 SQ S-Trim on my car and not only is it quiet, it has produced 668 horsepower at the wheels with a very conservative tune at 9.4psi, 14* of timing, 11.4 A/F ratio(build specs in my sig). When you factor in drivetrain loss of about 12%, that gives me 750+ flywheel horsepower. Andy at A&A Corvette is the best source for Vortech Supercharger kits and application advice. Good luck with your mods whichever unit you choose. There's nothing like the "rush of acceleration" from Forced Induction
** added 40rwhp and 2 psi to my numbers above..see sig below
Old Jul 1, 2007 | 10:51 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
Good to hear that Scotty! I can't wait til I've saved up for mine!
Old Jul 1, 2007 | 11:17 PM
NemesisC5's Avatar
NemesisC5
That'll be a smooth setup in your new "Sweet Azz" Black Widebody C6
Old Jul 2, 2007 | 01:25 AM
07MontRedcp's Avatar
07MontRedcp
I'll second that statement!!
BJK
Old Jul 2, 2007 | 11:37 AM
PcarRacr's Avatar
PcarRacr
Don't worry the Z06 kit uses the T-trim head unit so you should be fine for HP. Your limitation is the stock fuel system on the C6Z06.
I'm loving my Vortech kit. Any more power an only 3 and 4th would be useful. Right now the road surface has to be good for 2nd to even hold(and that's rolling onto the throttle carefully).
Enjoy!!!
Chad
Old Jul 3, 2007 | 12:43 AM
jnel04's Avatar
jnel04
Don't worry about the noise - I notice it, but that's because I'm listening for it. One corvette enthusiast noticed the noise, but that's just because he had one also and our belt was squeaking a little bit - an issue that has long since been resolved.
At idle it is just about impossible to tell - just a little bit of whine. The noise from the Vortech is almost unnoticeable with the windows up, but is audible with windows down when accelerating at moderate speeds.
btw... I'm tired and I'm not sure if that made any sense
Old Jul 3, 2007 | 05:28 PM
csun213's Avatar
csun213
I am thinking about getting a Vortech V2 SQ for a C6 A6, can someone tell me how is the low and mid end?
Old Jul 3, 2007 | 10:54 PM
kelp's Avatar
kelp
The unit is very noisy, until the gears are well oiled, after 20 minutes. And Vortec says that's the HP limit, although there are claims.... Also, keep in mind that's with an ideal setup with a C6Z. You will have to pull some stunts to get that.
Old Feb 23, 2009 | 06:49 PM
dgman2's Avatar
dgman2
Mine is a LS3 C6, but I'm sure that other than some HP difference your LS2 experience will be similar to mine.
At very low end, not much different than stock. Great to be able to cruise around & pretend to be civil. As your RPMs go up, so does your boost. Instead of having killer boost at low end, waisting rubber and challenging you ability to control your car, you'll experience rapid power gain through redline when you step on it (and I do mean RAPID). If you do not have good traction, you will have trouble controlling the car even with a centrifugal SC.
Having your A6 tranny tuned properly will make all the difference in your experience, though. My low end feels much more potent simply because of my recently improved shifting pattern.
Good luck.... get good tires if you do this!!
The new units are V2 Si and are supposed to be more efficient.
Old Feb 24, 2009 | 12:46 AM
JSB LS3's Avatar
JSB LS3
fwiw, my car has the Bosch BOV that's stock in the ECS Paxton kit and it makes EXACTLY the noise you're talking about. On the overrun or cruising under light throttle below 2000 RPM the car kind of sounds like a rattle snake....
Old Feb 24, 2009 | 03:01 AM
csun213's Avatar
csun213
Thanks but since this was an old thread I have already installed the Vortech T-trim. It has great power from 3000rpm to 6000rpm. Very happy with it.
To Vortech concerns.
