Procharger Help
Questions:
1. Is anyone having belt slippage with the 8psi 6 rib setup? I can't afford to do an 8 rib swap at this time.
2. I know that the 225 heads with the 8psi pulley will require the addition of a BAP and bigger injectors. Has anyone used the 205 heads and a blower cam and left the fuel system alone?
3. I know that the 225 heads and smaller pulley setup will make more power than the 205 heads with the stock pulley but any idea how much more?
I've been told that the AFR225 heads, which I have on my stock cube motor, have a larger bowl diameter then the cylinder bore. I haven't seen this first hand for myself because I don't have a need to take apart the motor but this info came from a reputable source who put the motor together. Just something to think about when making your decission.
My motor is all stock with the exception of the Procharger. My only concern is the difference in compression between the heads. The AFR 205 66cc heads and the AFR 225 65cc heads will nearly maintain the stock compression ratio and won't require an increase in boost to maintain the final compression ratio of the engine. I've been looking all over and I can't find any comparison between small and large cc heads on actual boost/hp.
Questions:
I have not had problems with the six rib assembly at 8 psi, keep the belt tension tight, and remember that a new belt stretches.
The stock fuel system is barely adequate at 8 psi. I would add a boost a pump when you add the heads. Since it sounds like you don't have a lot of disposable cash laying around, I would not add a head and cam combination to your car with a stock bottom end. The pistons may hold up, or they may not. It's a gamble at best. I would add a better camshaft, the boost a pump, possibly larger fuel injectors, and get the car tuned. Bob
