need help - experts please step in!
every time I hook up the diablo to see what codes I have, I get the MAP sensor.. MAP sensor.. MAP sensor.. MAP sensor.. MAP sensor..
is there any problem with my car? I got "Unknown" code too! what the hell is that too?
Thx!
If you don't get any codes onthe DIC, maybe the Diablo is showing older codes.
I don't have a Diablo, but with HP tuners, unless you clear the codes, you will see codes and might panic, but next to them it states history or other stuff, indicating that you HAD a code, but the problem may be corrected, but that history code not cleared.
Hope this helps.
If the car runs fine and no DIC codes, then that may be the case.
