C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
100 Shot?
Old Aug 14, 2007 | 02:34 PM
American Power's Avatar
American Power
Default 100 Shot?
Anyone blow an LSX motor with bolt ons and a 100shot wet kit?
I have been searching and it seems like the only people who have had issues is with a 150 shot or more.
Thanks.
Old Aug 14, 2007 | 03:31 PM
TLewis4095's Avatar
TLewis4095
You can blow a motor w/a 50 shot if not tuned right....but you should be more than safe up to a 150 wet shot.
Old Aug 14, 2007 | 04:22 PM
jogar80's Avatar
jogar80
Why dont you go with a dry shot? You can still damagae your engine, but I think what you are refering to is the intake backfire. Dry shots dont have fuel flowing through the intake, so there is nothing to ignite. Dry kits are also much cheaper. That, or you could also go direct Port I guess. But dont take my word for it, im just learning as well.
Old Aug 14, 2007 | 08:04 PM
Mr.Big's Avatar
Mr.Big
Dry is the only way to go on these systems, for several reasons... p.s. I'm running a 100hp dry shot on top of 700hp with great results on a STOCK bottom end... so I bet your car will do just fine...
Old Aug 14, 2007 | 08:29 PM
sux2bme's Avatar
sux2bme
When you say dry shot, is that the setup with a plate that goes behind the throttlebody?
Old Aug 14, 2007 | 08:32 PM
sux2bme's Avatar
sux2bme
If I can add more to this post:
Can you have your car tuned so that you can run on the motor by it self, then when you want to spray, trun it on and hit the button?
Old Aug 14, 2007 | 09:07 PM
TLewis4095's Avatar
TLewis4095
A dry kit sprays in the front of the MAF so the proper signals are sent to the computer and your fuel ratio is adjusted accordingly. The stock injectors are good to app.150 shot, but a 100 dry is super safe. You will need it tuned properly and the best set-up for what your looking for would be a remote bottle opener & bottle heater (so you can open it with a switch instead of stopping...opening the hatch/rear..etc), a wide open throttle switch (so it only sprays while the throttle is fully open to avoid build-up in manifold), and a widow switch to further assure that you don't spray before your RPM's are high enough for the motor to digest all that Nitrous/fuel/air being fed to the engine. With a set-up like that, you are guaranteed safe (as close as you can be) and can flip a switch to arm, do a few purges to insure lines are full, and hit the gas! Otherwise you are running NA with no additional stress to your drivetrain.
Old Aug 14, 2007 | 09:26 PM
sux2bme's Avatar
sux2bme
Who makes the best setup for the LS2, as a full kit?
Old Aug 14, 2007 | 11:54 PM
Mr.Big's Avatar
Mr.Big
TLewis said it well...I would only add a NO2 pressure gauge to his suggestions... A few install ideas for you...
Old Aug 15, 2007 | 08:56 AM
American Power
So a LS7 with cam and bolt ons with stock bottom end can handle a 100 shot dry or wet...
Also 100 shot doesn't mean 100HP right. I have seen guys dyno with these with like 150 more Horse. How do you know what jet size to start with for a 100 shot
Thanks for all the replies..
Old Aug 15, 2007 | 09:53 AM
jogar80's Avatar
jogar80
Well usually a 100 shot will net you about 100 hp at the wheels. As far as which jets to use, when you buy a kit, you usually get several jets included, and a sheet that tells you which jets to use for what size shot.
Old Aug 15, 2007 | 09:56 AM
jogar80's Avatar
jogar80
Harris Speed Works has a pretty good Dry kit that you can start withhttp://www.harrisspeedworks.com/shop/home.php?cat=365. You can also try http://www.nitrousoutlet.com they are very good about answering questions and have great products.
Old Aug 17, 2007 | 01:58 AM
SoldSyclone's Avatar
SoldSyclone
Nitrous Outlet Plate Kit
http://forums.corvetteforum.com/show....php?t=1719995
Old Aug 17, 2007 | 02:24 PM
jogar80's Avatar
jogar80
If you want a wet kit, the nitrous outlet plate kit is a very clean lookin piece. Kinda stealthy, which I like. My current kit is a TNT Power Ring kit. Also great, but not stealthy at all, lol.
Old Aug 17, 2007 | 05:01 PM
American Power
I like the idea of a throttle body spacer/plate.. Who makes it??
Old Aug 17, 2007 | 05:07 PM
American Power
I read the previous post. I got it! thanks.. I'll let you know when I do it. 100 extra ponies is all the insurance I need and should be entertaining! I'll have before and After dyno #s.
Old Sep 6, 2007 | 08:29 AM
Magellan62's Avatar
Magellan62
Default Arming Switches
Mr. Big
Very clean arming setup. Where did you source the switches. Looks like you have four there, what is the funtion if each?
Sammy
To 100 Shot?
Old Sep 6, 2007 | 10:17 AM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
WOW!!!!! Mr. Big very cool!!! I guess I really wont have to worry about my stock bottom end blowing up FI to "only" 525/500 with a Paxton then.
Old Sep 11, 2007 | 11:27 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Originally Posted by Magellan62
Mr. Big
Sammy
I hope Mr. Big doesn't mind if I take a stab at that.
1. Nitrous Arm
2. Bottle Heater
3. Remote Bottle Opener
4. Purge
Old Sep 11, 2007 | 02:32 PM
Mr.Big's Avatar
Mr.Big
1. Nitrous Arm
2. Bottle Heater
4. Purge
Right on... Switches with led confirmation lights sourced at autozone... purge button and rocker for bottle opener came with the kit that Dave at www.nitrousoutlet.com customized for me, guarded switch for bottle heater came from Fry's electronics.
