C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Meth injection question
Old Oct 7, 2007 | 07:18 PM
ayousef's Avatar
ayousef
Default Meth injection question
As usual I could benefit from a few real world experiences/numbers etc...
My current set-up is a vortech supercharged Z06, low boost ~4 PSI. I am currently at 130 RWHP above stock. I will soon do a cam swap that is worth ~50 RWHP, and I want to top that off with added cooling, safety and a "little" more power.
How noticeable is the meth cooling effect, and how much power will I be able to get out of the kit. I will not be using the kit continously, infact under very normal driving I would like to switch off the injection and turn it on when its needed
Also how much do they sell for, thanks!
Old Oct 7, 2007 | 09:53 PM
ayousef's Avatar
ayousef
ttt
Old Oct 8, 2007 | 08:21 AM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
Mine was set to come on at wide open throttle and at 3.5K rpms and turn off at 6K rpms. It was worth about 75rwhp. It is very noticable when the meth comes on. It kind of feels like nitrous. I did not get a chance to actually see how much it lowered my temps, but it was very cold to the touch
John
Old Oct 8, 2007 | 09:52 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
There really isn't any reason to turn it on and off, our meth kit only comes on under boost, that is predetermined, so it only used when needed. You could travel across the country and never use any if stay under the boost level you set it for. Shutting it off could open the door for a potential problem if you forget to turn it back on.
Old Oct 8, 2007 | 12:04 PM
CHARGED UP's Avatar
CHARGED UP
St. Jude Donor '13-'14-'15-'16
Default meth
Go with the ECS advice I just did mine after asking same question. Picked mine up Friday & all I can say is WOW ! Good people to deal with.
Old Oct 8, 2007 | 12:38 PM
ayousef's Avatar
ayousef
Thanks for the response Doug.
How much power do you think I could pick up with the meth kit on my setup, thanks.
Old Oct 8, 2007 | 01:01 PM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Be sure to contact Andy at A&A Corvette and inquire about their methanol injection system.
www.aandacorvette.com
(888) VETTEPRO
Ask for Andy
Old Oct 8, 2007 | 06:10 PM
pennys58's Avatar
pennys58
SC CF Senior Member
You're right, it was 4lbs. of boost when it comes on Haven't been in it in so long I forgot
John
Old Oct 8, 2007 | 06:36 PM
ayousef's Avatar
ayousef
John
btw 75 RWHP is crazy thats as you stated almost like NOS. Do you have a graph or something that shows the be4/after?
To Meth injection question
