Wow!...great to know headers and exhaust let's the horses out!!!
It sounds like the think is going to be a complete beast! Please keep us all updated. I feel sorry for the clutch and half-shafts as they are going to feel what "real" hp feels like!
Cheers,
Chad
Soon we we get some numbers I will update you I really don't know what to expect, but am eager to find out.
Wow!...great to know headers and exhaust let's the horses out!!! WGT do you also have full exaust? Do you still have the aftermarket CAM in it?
From what I've heard the stock fuel system can safely support around that 575RWHP number. I know that PIO had A&A make a few changes and instantly the car went up 30rwhp.
As far as tires go I've been asking the same questions as even with my measely 576rwhp 1st and 2nd are useless at anywhere near full throttle. I think WGT uses Hoosier A6(autocross compound) and is happy. If its a car not driven much(mileage wise) that may be the only way to go as those guys won't last too long. Fun in the rain though...lol.
Also sounds like the Nitto INVO's may be a little better than the goodyears. I hear they are a 1/2" taller which for our big hp cars would be a bad thing. May affect speedo accuracy though.
Cheers,
Chad
Hi Chad,
Yes I still have an aftermarket cam in my setup. I have Kooks headers too, but stock exhaust.
I personally use a wideband air/fuel meter, a knock indicator, electronic boost controller, boost gauge, egt, and audible/visual alarm indicators for all gauges, including other non forced induction specific guages (oil temp & pressure, water temp) on my turbocharged car (my vette only has 270 miles on it). It's very cheap insurance.
The first thing I'd want from my tuner is a dyno graph showing hp, tq, and more importantly air/fuel levels. As others have said it was almost certainly the tune.
Even though you're building the block, you can still blow it up with a bad tune, especially if you're going to utilize the stock compression ratio. Personally, if was building the block I'd go with a lower compression ratio than stock to allow for more boost. Depending on the amount of boost, I'd want to keep the air/fuel ratios around 12:1 or maybe 12.5:1. I'd also look into water/meth/etc injection to insure even more safety and effectively upgrade your fuel octane economically. Just additional insurance, and that's a fairly expensive toy, especially after an engine rebuild.
Good luck, and I'd like to see your results. I think I'll be looking at a turbo or s/c setup down the road so I "lurk" this forum often.
I didn't see this posted yet. Don't forget that the factory head bolts on the LS2/7 are torque to yield. There is a good possibilty that the car actually stretched the head bolts, leading to the blown head gasket. As far as the motor issue goes, I tend to agree with everyone else. The LS7 has more compression than the LS2 meaning that there must be a significant lowering of your timing. Especially under WOT. My car makes over 700 with 12psi and we don't have problems using 93 octane fuel. However I'm not running crazy amounts of timing. With the higher comp. motor I would imagine timing would need to be in the neighborhood of 16*at WOT. Maybe less? Perry would probably be able to tell you a good number to start at. Good luck
The problem was not with any head bolts. The car was leaning out in higher RPMs.
San
San, I'd shoot for a little of a richer tune. We shoot for an air/fuel ratio of 11.5/1 to be safe. Bob
I run right at 11:1 and a bit under at full boost on pump and right at 12:1 or a bit more with half race/half pump, but wasn't sure what you guys run as this is my first vette. What air/fuel ratios do you run with water/meth/etc injection?
San
We still run 11.5/1 to be safe. With the meth we can add more timing, which makes a big gain in horsepower. Bob
If the water methanol injection system is installed and tuned correctly, your ECU will automatically reduce ignition timing and add fuel in the event the air temps rise as a result of the water alcohol injection system running out of fluid or failing.
How do we do this?
It's simple. On the Corvettes the IAT (intake air temperature) sensor is located in the mass air meter. Since we do not want to spray the water methanol mixture through the mass air meter, injection will have to take place just after it. By injecting after the IAT sensor the ECU is not able to recognize the air temperature drop from the water methanol injection.
By relocating the IAT sensor in the manifold the ECU can now recognize the drop in air temps allowing us to tune off of it. That way if air inlet temps rise due to the water methanol injection running out of fluid or system failure, we can tune the ECU to significantly reduce ignition timing and add fuel to protect the motor. This can only be done if the IAT sensor is located after the water methanol injection. Not before it.
How do we do this?
What a great post. I predict that some day people are going to dump front mount intercoolers and just use meth as an intercooler. In fact, i am certain that meth injection provides much better cooling than a front mount intercooler. Whay would i get rid of the front moount intercooler? Well it blocks air flow to the radiator and makes is difficult to road race with AND it adds weight to the front of the car.
BTW, where exactly would you put the IAT sensor in the manifold? Do you have a picture of this setup?
well, i was going to strap a procharger on mine limited to 5 psi, but after reading this crap, I am going to stick with the 3:90 diff decision
There is nothing wrong with getting a Procharger and limiting it to 5 psi. With a Procharger, you could probably do a little more on the LS1 too. The entire point of this post is that the car has to be tuned properly.
I don't have any pictures of just this. You might find some on here if you do a search. This procedure varies as the 1997-2001 have the IAT sensor separate while the 2002 and later have the IAT in the mass air meter. Depending on the manifold and supercharger used the location varies. Many of the shops are well familiar with this as it's become common practice to relocate it after the water/methanol injection.
I have 13* timing w/meth on my LS2 using 91 octane and A/F ratio is 12.0
BJK
