C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Electronic Boost Gauge?
Old Nov 16, 2007 | 03:52 PM
ayousef's Avatar
ayousef
Default Electronic Boost Gauge?
question is, how do they work.
I am installing a vaccum gauge on my car, and I am wondering how the electronic ones function. Where is the boost pressure read from? I understand that the MAF can only read up to atmospheric pressure. This also makes me wonder, how some devices such as the "diablo predator" read boost from the PCM.
Old Nov 16, 2007 | 05:32 PM
1QWKLS3's Avatar
1QWKLS3
8th Gear
You still have to tap a vacum source, it just doesn't run into the car. The output from the sensor is sent to the gauge. I run the Defi set-up.
Old Nov 16, 2007 | 06:10 PM
dgcarver's Avatar
dgcarver
The MAP (Manifold Absolute Pressure) reads the vacuum on the manifold and inputs the signal back to the computer. You are correct, it only reads up to 1 Atm or 14.7 psi absolute or outside pressure. For boost applications, you really need to replace the 1 bar MAP with a 2 or 3 bar MAP and retune the computer with software like HP Tuner.
To Electronic Boost Gauge?
