C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost a pump
Old Dec 9, 2007 | 04:54 PM
SpinMonster's Avatar
SpinMonster
Default Boost a pump
What is involved with the install? I saw that it can be mounted in the eng compartment. Is it simply a power plus 2 wires not counting the control ****?
Old Dec 9, 2007 | 09:34 PM
excessive81's Avatar
excessive81
pretty much but no ****. there a dial on the unit. i bought one new from a guy here a while ago that neve got on the car if you are interested. also have a 4.5 pulley that is new as well. i building a forged stroked ls3 so i be doing entire fuel system
Old Dec 10, 2007 | 01:34 AM
SpinMonster
I can get them pretty cheap from connections. Thanks anyway.
Old Dec 10, 2007 | 11:11 AM
vettl83's Avatar
vettl83
Spin if it's like the Magna Volt there are 5 wires and a vaccume hose.
Red hot, Black ground, Gray, White, fuel pump relays, and yellow goes to the intercooler water pump. It's supposed to supply more voltage to the fuel pumps under booste conditions to make more fuel pressure as directed by vaccume.
Old Dec 10, 2007 | 08:12 PM
BAADC6's Avatar
BAADC6
I just had a Kenne Bell boost-a-pump installed. I'll try to get some more info on it. FYI - I am trying to make it to Cartek on thursday if you still want to try a ride??
Old Dec 12, 2007 | 11:43 AM
MDMCZ06's Avatar
0MDMCZ06
Former Vendor
Spin,
do yourself a favor. Cut off the rheostat and connect the two wires together so you get the full 50% increase whenever you're in boost. Then all you have to do is wire the BAP into the grey wire for your fuel pump circuit, and run the 2 wires for the PSI switch.
I have a diagram, PM me if you want a copy.
Ed
Old Dec 16, 2007 | 06:33 AM
Electro649's Avatar
Electro649
Cruising
Ed,
Can you send me the Boost a Pump diagram?
Erik ....................electro649@telus.net
Old Dec 23, 2007 | 02:49 PM
zo6landrocket's Avatar
zo6landrocket
Originally Posted by Electro649
Ed,
Me too please...........decalpha@hotmail.com
Old Dec 23, 2007 | 03:40 PM
mr.algaz's Avatar
mr.algaz
Me three please......... mr.algaz@gmail.com
To Boost a pump
