I'm trying to track down the approximate weight of the various tt, centri, and lobed FI kits out there. The shipping weight is fine as I'm guessing the packaging weight would be similar. If anyone still has the shipping container(s), the shipping label should show the weight.
I understand that the different approaches distribute the weight differently. I'm just looking for a to-the-nearest-5-pounds ballpark on the total. TIA
I wish I had kept the shipping container my C5 Maggie kit came in. The blower+intake assembly can't have been much more than 60 pounds because I was able to softly place it on the engine without help, and I'm neither big nor particularly strong. But I did have to readjust the front ride height after installation! My guess is that it is also near 100 pounds total after you add all the intercooler stuff, including the water, but that is just a guess!
Prior to installing TT kit I lowered the front all the way down on the stock ride height/leaf spring adjusters and had no real issues with scraping. After installing the TT kit my front end dropped quite a bit. The air dam now scrapes over everything including small divets in the road. The air dam sits about an inch off the ground.
My guess is the APS TT kit has added close to 150+lbs considering the twin intercoolers, additional water/coolant, cast manifolds (compared to stainless headers) and all the hardware.
I wish I had an accurate weight for you as I would like to know myself. It is a substantial increase though.
same here its soo annoying though, going to raise it back in a few days.
I have an APS FMIC on my other car and I noticed a difference. The last place I want to add weight on the Corvette is in the front of the car. Decisions, decisions.
My Maggie install kit i.e. intercooler, h20 pump, h20 tank, hoses, Magna Volt, belt tensioner, idler pulley, crank pinning kit, wiring, etc. was 40 lbs. I figure net weight to be around 30 lbs. The Magna Charger itself is around 45 lbs. to 50 lbs. however sitting in the engine valley the weight should be distributed evenly.
