Boost ad headunits
A given engine will consume the same volume of air if you pressurize the intake to 10 psi with the smallest Vortech or the largest Procharger. Obviously, the larger head unit will be able to deliver more boost to a given engine than the smaller head unit if you let it. And the larger blower can pressurize a much larger engine to 10 psi than a small blower.
Another thing to remember is that boost comes from restriction of flow. The blower is trying to move more air than the engine can consume. Suppose you bolt a blower kit on the mildest truck motor out there, one designed for maximum torque at trailer towing engine speeds. Suppose you pulley the blower to deliver a max boost of 10 psi. Now you improve the engine's ability to breathe by swapping on big valve ported heads, installing a bigger cam, and free flowing intake and exhaust systems. When you bolt your blower on with the same pulleys as before, you are almost certainly going to see less boost than you had before. Your engine is less of a restriction than it was before, and can consume more of the blower's output without an increase in intake manifold pressure.
This is how one engine can make 450 hp at 10 psi while another engine of the same displacement can make 650 hp at 6 psi. It's all in the breathing!
There are so many things that can influence this, such as the cam duration and lift. The higher and longer the valve stays open the more it will allow air to flow in, just like the added headers will allow gases to flow out easiler and droping the psi because there is less "left over air if you will" left in the combution chamber. There is know way to easily explain it, but just know that a bigger blower with less boost, more belt wrap because you are using a larger pulley which will eliminate belt slip, and high compression is the way to go IMHO. (Don't forget the meth)
Exactly what I've been doing.
All centifugal compressors heat the air as they compress it. Less efficient compressors have a higher discharge temp than more efficient compressors. And the efficiency of any given compressor is not a constant across its map of pressure ratio versus flow rate. You want to pick a head unit that will operate efficiently given your planned boost and your engine's air flow capability.
Sure wish I had a Procharger compressor map. Hard to pick a head unit without one. With the low boost pressure ratio I am operating on, I am certain I am not operating my D1SC in the most efficient islands. I see IATs in the 130s to 150s, but it still makes 680 rwhp, however (5.7 psi).
show us pics man
