C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel Injectors
Old Dec 27, 2007 | 03:29 AM
sacegielski's Avatar
sacegielski
Default Fuel Injectors
Note: With the recommedation of another member I'm bringing this question to you guys on this side... See below.
I've used the search, but really couldn't find the answer to my question. With that being said, I've come to ask for your help.
As of late, I've been wondering if I'm starving my system of fuel, possibly needing larger fuel injectors. Ultimately, leaving a little HP on the table. At what point do you cross the threshold of having to replace them? Presently making 460rwhp / 412rwtq.
Current Setup:
Stage IIE Heads
S+ Cam (238/242 113 LSA .605/.610)
Ported TB
Fast 90
CAI
1 7/8 LT w/ Hi-Flo cats
Underdrive Pulley
I've found a set of LS2 "Direct-Fit" 46lb/hr injectors from Racetronix website, but not certain if I stand to gain anything from the change. Even if nothing is gained, I still want to change them out if my stock injectors are no longer adequate for the job.
Old Dec 27, 2007 | 01:25 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Current Setup:
Stage IIE Heads
Ported TB
Fast 90
CAI
Underdrive Pulley
A) Get it checked by a tuner for % utilization of injectors.
B) What is your A/F during PE?
Answer those and then decide if you need bigger injectors. If you are over 80 to 85% utilization, you might consider bigger injectors. If I were at 85%, I would stand pat UNLESS I had more plans to increase the HP.
Elmer
Old Dec 28, 2007 | 05:47 PM
sacegielski
Gotcha brotha...
Old Jan 22, 2008 | 06:47 AM
EPP's Avatar
0EPP
Former Vendor
Elmer
Great info, I agree. You need to know what the duty cycle and fuel pressure is to know if you need larger injectors.
Old Feb 7, 2008 | 12:46 AM
jhaines's Avatar
0jhaines
Former Vendor
Default LS2 injector replacement
Although I agree with the other people that said to check your air-fuel ratio (with a real air-fuel ratio meter) and to check your injector duty cycle, if you know how much power you are making at the rear wheels you can get a fairly close idea of how much fuel you are using and how close you are to being out of injector.
Since you mention drop-in replacement LS2 injectors, I am assuming your car is an LS2 Corvette (and not a Z06 with the LS7).
The LS2 injectors are rated at 33.9 lbs/hr (or 4.27 grams/second).
If you are making 460 rwhp that is around 520 to 540 hp at the crankshaft (using 12% to 15% losses assuming you have a manual transmission vehicle).
Brake specific fuel consumption (BSFC) is a measure of the amount of fuel it takes to make horsepower. The common units used in the US are lbs/hr/hp. A 0.45 BSFC fuel consumption is about as good as you are going to get on a naturally aspirated street engine on pump gas (and it could be slightly worse, a range of 0.45 to 0.50 is usually used for a naturally aspirated street engine). If this were a boosted engine then your BSFC would likely be closer to 0.55 to 0.60.
At 540 hp and a brake specific fuel consumption (BSFC) of 0.45, you are consuming 243 lbs/hr of fuel (540 hp * 0.45 lbs/hr/hp= 243 lbs/hr). With 8 injectors, that means each injector needs to deliver 30.4 lbs/hr of fuel (243 lbs/hr / 8 = 30.4 lbs/hr). Since the injectors are rated at 33.9 lbs/hr, you are at 90% duty cycle (30.4/33.9=0.896). This is assuming the 0.45 BSFC and 540 crank hp. At 520 hp, you would be at 86% duty cycle. At 0.50 BSFC and 540 crank hp, you would be at 100% duty cycle. These percentages are slightly off since it actually takes a certain amount of time to open and close the injector and during part of that time, fuel is not flowing through the injector. Most engine management systems have a minimum off time that they give the injectors (so you never really get to 100% duty cycle).
So, to make a long story short, you are likely out of injector or almost out of injector. Going to larger injectors would be recommended at your power level. You probably won't make more power (unless you are running much too lean) but you will be back in fuel control and are less likely to damage your engine.
If you are loosing fuel pressure for any reason, then your effective injector size is even smaller and you are even more likely to be out of injector. Also, as fuel temperatures increase, the density of the fuel decreases so you need more volume of fuel to maintain the same number of fuel atoms (the same mass of fuel) so as fuel temperature goes up you need more volume of fluid to keep the same air-fuel ratio.
Sorry if this ended up being longer than intended.
Current Setup:
Stage IIE Heads
Ported TB
Fast 90
CAI
Underdrive Pulley
Last edited by jhaines; Feb 7, 2008 at 02:45 AM. Reason: Added fuel temperature and pressure information. Clarified some math.
Old Feb 7, 2008 | 01:48 AM
Mr.Big's Avatar
Mr.Big
Wow... nice help...
Old Feb 7, 2008 | 10:08 AM
4evervette's Avatar
4evervette
grreat info ....
Old Feb 7, 2008 | 11:08 AM
chxwing's Avatar
chxwing
Would you figure your fuel needed the same way if it was sc car.
David
Old Feb 7, 2008 | 11:18 AM
jhaines's Avatar
0jhaines
Former Vendor
Default SC fuel requirements
Yes, but a supercharged car would use the 0.55 to 0.60 BSFC figures I mentioned.
BTW - the total fuel flow before you devide by the number of injectors is how much pump flow you need. You actually need a margin of extra fuel pump flow as well to compensate for hot fuel handling and to run the jet (venturi) pumps that fill the canister and transfer fuel from the passenger side tank to the driver side tank. We normally like to see 10% to cover hot fuel handling and jet pump operation. When we flow test pumps in our test cells we usually try to test the complete system including the jet pumps.
David
Old Feb 13, 2008 | 09:56 PM
extremecorvette's Avatar
extremecorvette
I get my APS Z06 kit I will be selling off the new 60lb injectors. I'm going with large in injectors 83lb
Old Feb 14, 2008 | 12:03 AM
aTX427
Guest
Posts: n/a
Who makes 83lb high impedance injectors? The highest I found were Racetronix 79's.
Old Feb 14, 2008 | 09:56 AM
extremecorvette
Call LS1 Speed Inc.
I don't have the paper work on them here at work.
Old Feb 15, 2008 | 09:19 AM
sacegielski
Actually, I appreciate the long explanation, so there is no need to apologize .
With everything you said, it only makes sense to replace the injectors. Especially if I want to be in control of my fuel again. Granted, fuel pressure isn't dropping, but with Texas summers being as hot as they are, it's better to be safe rather than sorry. Consider it cheap insurance!
Old Feb 15, 2008 | 04:11 PM
EC_Tune's Avatar
EC_Tune
Actually hotter air is less dense so you will be using less fuel not more in the summer. And your HP in the summer will be less as well because of the additional heat.
Old Feb 16, 2008 | 02:03 AM
JustLucky's Avatar
JustLucky
Some great info in here!
To Fuel Injectors
