C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Need help on fuel pressure problem.
Old Jan 18, 2008 | 10:40 PM
csun213's Avatar
csun213
Default Need help on fuel pressure problem.
Hi, I have posted this on the Tech section also.
I am going to my tuner to find out why my pressure is dropping. The fuel pump was tested and was in the acceptable range.
My fuel pressure gauge was also tested and found to be accurate.
The pressure would start about 70-71psi (I know that 70 psi is high but that is what it shows) when the engine is cold then it would just start to drop slowly as the engine warms up. After about 15 minutes at idle, the fuel pressure would start at about 70 psi and then drop to about 60 psi. I was told that the fuel pump pressure is good as long as the fuel pressure is above 55 psi.
I am going to add a boost a pump later but just want to see if anyone out there knows the cause of this problem and whether a boost a pump is the fix.
The problem started after the car was parked for about 4 weeks.
Someone was telling me that maybe the fuel filter was clogged by junk that had sat in the bottom of the fuel tank, gotten sucked up and clogged the fuel filter. However this would not explain why the pressure would drop when hot. Wouldn't the pressure be low the whole time regardless of heat?
Any help would be greatly appreciated.
Old Jan 18, 2008 | 11:32 PM
saplumr's Avatar
saplumr
I would think the filter "could" be a problem. Is it possible to have someting moving back and forth in the filter causing flow issues?? Is it posssible you have a low voltage problem?? Seems that if your car has had proper fuel pressure then all of a sudden it changes, unless you have a blower, a BAP should not be necessary and may do nothing but mask your real problem. Good luck.
Old Jan 19, 2008 | 11:40 AM
csun213's Avatar
csun213
I do have a supercharger but was told after the dyno tune that I would not need a BAP since my fuel pressure was fine at WOT.
Just don't know why the sudden fuel pressure drop after the engine is hot now.
Old Jan 19, 2008 | 02:29 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Try this:
http://www.ls2.com/boggs/fueldisc/fuelsystemdiag.htm
Elmer
Old Jan 19, 2008 | 05:21 PM
csun213's Avatar
csun213
Thanks.
Old Jan 19, 2008 | 07:53 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
You need to get the guage checked , check the fuel pressure at the rail - I have been doing research myself for my own car , and 70Psi on the stock pump is not possible , so your initial reading is not good . Sounds to me like your gauge is the problem .
Good luck
Old Jan 19, 2008 | 10:45 PM
csun213's Avatar
csun213
Good luck
Thanks, I will get the guage checked again by my tuner. I am hoping the gauge is bad (cheaper than any other problems).
To Need help on fuel pressure problem.
