C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Help with boost gauge!!!
Old Jan 22, 2008 | 12:39 PM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
Default Help with boost gauge!!!
Hello,
I am about to install a boost gauge on my C6 Z06 and would like to know which cable has 12V WHILE cranking?
Thanks in advance
Old Jan 24, 2008 | 11:55 PM
HyeSpeeder's Avatar
HyeSpeeder
Use a multimeter to check which wire has power while cranking
Why do you need it while it cranking?
Gev
Old Jan 25, 2008 | 09:37 AM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
Gev
That is what the instructions say. AutoMeter says it will give false readings if it is not connected like that.
Old Jan 25, 2008 | 11:59 AM
HyeSpeeder's Avatar
HyeSpeeder
Which gauge is it? do you have the part number or a link ? Ill check it out
Old Jan 26, 2008 | 04:12 AM
Doubletap's Avatar
Doubletap
St. Jude Donor '08-'09-'12
Got this pic from another forum member..
Yellow wire is located under the steering column big bundle of wires (12v switched)
I hooked the dash lights up to the gray wire coming off the dimmer switch.
Old Jan 28, 2008 | 10:42 AM
ALTECH's Avatar
ALTECH
St. Jude Donor '14
Auto Meter #6359
Old Mar 17, 2008 | 09:27 PM
jdfox678's Avatar
jdfox678
Is it a plain gray wire for the dimmer?? And is it connected right to the switch? I don't think my car has a gray wire there.
To Help with boost gauge!!!
