C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
APS TT Check Engine Light
Old Jan 22, 2008 | 08:56 PM
gemtcoinc's Avatar
gemtcoinc
Default APS TT Check Engine Light
Does anyone ells with a APS TT system have a problem with there check engine light staying on ? I have the system on an 07 Z51 Vert running the APS 3" exhaust ( Sounds Sweet) This car is no joke!! kind of like a high powerd pistol with a 1lb pull, you had better have it pointed in a safe direction before you touch the trigger. I love the way it runs I just cannot get it inspected. I hade it installed at XX Tunning, I need to give them a call, Just wondering if anyone ells is having an issue as well.
GC
Old Jan 23, 2008 | 09:52 AM
MadBoost's Avatar
MadBoost
GC
You answered your own question. Give them a call or swing by a local dealer and find out what the code is so that we can be of more assistance. May have nothing to do with the APS system.
Old Jan 23, 2008 | 02:58 PM
427fIc5z06's Avatar
427fIc5z06
GC
On the C5's, you can read and clear the Diagnostic Trouble Codes right off the DIC. Check out this link (below) and see if it works for you. If it does, then you can post the codes that you discover. Perhaps helpful suggestions would then emerge.
By the way, you should also go back to your tuner to see what they may be able to say... Good luck!
http://forums.corvetteforum.com/show...ht=reading+DTC
Old Jan 23, 2008 | 03:52 PM
jonjon's Avatar
jonjon
You'll have to get a hand held scanner to read the codes. If you don't have one either go to autozone and have them read it or buy/borrow one and post the code you get.
Old Jan 24, 2008 | 10:00 PM
DSOMC6's Avatar
DSOMC6
I have the same TT's, exhaust system, and also have a cam added in an 06. I also throw a CEL from time to time. It usually clears in a day or two. I wouldn't pay it too much attention if the car is running spot on and no other indication of something a miss. Get it checked if you are worried about it. I agree the car sounds bad a$$ with the 3" APS exhaust.
To APS TT Check Engine Light
