Just got a C6, time for Boost.
First off I am going to blower route to keep it simple. Also I want to keep the stock rear end and tranny. Also stock block and internals. I plan on a full header-back exhaust system first. Next I have seen many s/c options. Which blower kit is going to give you the most performance for value (also which one is the best performing)? Also with the kit what is the highest boost level you can safely run with stock internals?
My next question what is the best 1/4 mile time C6s are running with a set-up similar to what I am looking at with a really good dyno tune?
Sorry for the newbie questions, but I really want to keep all my questions in one thread so I can start this build right away.
http://www.exoticperformanceplus.com...Car.php?car=30 Bob
I like the procharger setup, it looks clean.
But with a blower and headerback could 10s be possible... is there a head/cam set up that works well with a procharger set-up?
While the LS2 cam isn't the best for boosted applications, it's certainly not necessary to swap it out.
I do have some nice blower cams, if you do decide to go that way.
My system includes your injectors, fuel system upgrade, and pretty much everything you need for the install.
It's also a very clean looking setup.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
If you are looking for a complete setup, ready to bolt-on, that can make over 500rwhp on the stock bottom end; then I would recommend the Magnacharger system for you. It is a very clean install and makes HP and torque in all areas of the RPM band. It is very reliable and in my opinion gives you the best performance for your valued dollar. There are many members still using their stock bottom end, rear end, and transmissions with a Maggie setup and they will attest to the Maggie's performance. Although I believe any stock clutch wrestling with more than 450rwhp is on borrowed time... Any supercharger system will respond well to a set of Long Tube headers and a catback exhaust system. You will most likely lose around 1lb. of boost with the addition of LT's and a catback, but since you mentioned having a custom dyno tune, you could always add a smaller pulley to regain the lost boost and add a custom tune on the dyno to tune for more HP. I would recommend nothing more than 10lbs of boost on the stock bottom end/stock compression ratio - 8lbs of boost is just about right on the stock bottom end. With the Z51 suspension and a 6-spd manual you should have no problems running low 11's with a Maggie setup and LT's on the stock bottom end. If you throw in a set of slicks, an upgraded clutch, a smaller pulley, and a custom tune, 10's are in reach. Just to clarify you will need to change out your hood for the addition of a Magnacharger as it will not fit underneath the stock hood but there are many hoods available and the addition of a custom hood will set your 'Vette apart from the rest, if they can even see your hood from the back as you "blow" past them... Hope this helps you out!
BTW: I noticed you mentioned that you just sold your TBSS, I have a TBSS that I am getting ready to install a Magnacharger on, so if you have any more questions feel free to ask or PM me. I would be glad to help.
http://www.eastcoastsupercharging.com/SC600.html
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
More important than which SC to go with, is WHO is doing the install. Even a good (fully engineered) SC kit will be a complete headache if it is improperly installed and/or tuned.
Don't be hung up on "the ultimate setup", as it doesn't exist. Anything over 600rwhp is just bragging rights. If you're going to be drag racing with hard launches, you'll need an aftermarket clutch. With a blower, drag radials, and a GOOD DRIVER, you'll be in the 10s.
IMHO, if you are in California, take your car to A&A Corvette in Oxnard. http://www.aacorvette.com/
If you are on the East Coast, take your car to ECS in New Jersey. http://www.eastcoastsupercharging.com/
These are two of the most highly regarded shops in the world for Corvettes. Both shops have done countless installs, and have excellent customer service before, during and after the sale. With these shops you don't just get a blower, you get a fully engineered kit. With either shop, you'll get a fully-functioning well-sorted install.
Best of luck.
