C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
e85 for FI
Old Feb 16, 2008 | 10:58 AM
Busa196's Avatar
Busa196
I'm probably missing something here, but why not just install a $500 meth kit, have the car dialed in on a dyno and be done with it? It'll offer the same advantages and there's no "maintenance" needed with it other than filling the tank every 3-4 weeks. Changing the entire fuel system for the same/similar desired results seems to be overkill.
Again, I'm not familir with E85 so maybe there's other advantages that it offers that meth doesn't??
Old Feb 16, 2008 | 12:06 PM
aTX427
Guest
Posts: n/a
Mr. Big, do you know what changed king of changes they made.
Vettalot, I have not read any information about ethanol being corrosive to the parts in modern vehicals. Methanol is an entirely different storry, however you bring up good points that need further investigarion with regards to the knock sensor, o2 sensors, bare aluminum parts in the fuel pump. I cannot imagine there being a risk of arcing of parts inside the take as gasoline would be more of a risk than ethanol, but will consult a fuel system expert, i.e., Racetronix. Our tanks are already made of plastic, but I will look into the type to ensure there is compatibility with ethanol.
Busa, I really don't want to add / rely / maintain an additional system. Ethanol will provide much lower AIT's and near elimination of detonation. The meth injection is still a very small percentage when sprayed (<1%), where e85 is 85% ethanol.
Keep in mind, my information is still based on reading and by no means expert / first had opinion, so please keep the input coming.
Old Feb 17, 2008 | 11:10 AM
wallyj's Avatar
wallyj
Default Some great info over at LS1tech.com
http://www.ls1tech.com/forums/showth...&highlight=e85
Old Feb 17, 2008 | 12:35 PM
shizon'00's Avatar
shizon'00
We're doing it on my wife's Procharged GTO. Big power increase over 93 for sure! We did up the boost 1 psi, but the only other thing we added was E85 and some tuning and made 70+rwhp more.
Old Feb 24, 2008 | 10:56 AM
excessive81's Avatar
excessive81
i went to a party last night and spoke with a guy that works for irl....they converted to e85 a couple years ago and seen a 30%increase in fuel econ. i actualy was asking about the pace car this year that is a zo6 running e85. his comment was that flex fuel cars and trucks see lower mpg becausue they are tuned to run both e85 and gasoline. he says if you just tune for the e85 and run it only that fuel mileage should not drop much at all. soi am doing lots of research as it seems like my new motor is a very good canidate...1000 hp on moonshine lol
Old Feb 24, 2008 | 02:39 PM
aTX427
Guest
Posts: n/a
Finding a tunre down south is going to be a challenge for me.
Old Feb 24, 2008 | 04:18 PM
drivinfast's Avatar
drivinfast
It wouldn't be the first time that Wikipedia had outdated info : I just cut and pasted, I have deleted the quote from my post, and retained the link. The LS1 link from the user in Sweden is much more informative.
Old Feb 26, 2008 | 05:05 PM
shizon'00's Avatar
shizon'00
It's really not true. Same motor built for gas will have worse gas mileage on E85. If you want to see a C6 running on E85, let me know. I can also show you a 1000hp ls1 (wife's goat) running on E85
Old Feb 26, 2008 | 05:42 PM
excessive81
heck yeah i want to c!!!!! wife car with 1000 hp...how cool is that
Old Feb 26, 2008 | 08:05 PM
Jake@EPP's Avatar
0Jake@EPP
Former Vendor
The biggest thing on e85 for a higher hp car, is fuel consistency. When purchasing the e85, you may or may not get the same blend, same as 93 pump. There IS going to be variance, how much, well it has a TON of factors.
There is also another good point made over on ls1tech. It is a good idea to speak with a knowledgeable engine builder that builds cars for e85, more so alcohol. They are setup very different then a gasoline motor, there will be some similarities and various differences.
I can see from a financial point why people want to switch, but risking a motor to save a few bucks is beyond me. If there was a guarantee that the fuel you purchased was in fact the same blend (e85) you tuned on, then thats great. But with the amount of cylinder pressure at 900+ rwhp there is not much if any margin for error. This is why race fuel is as much as it is, if you buy C16(116 octane), you will get 116 octane.
Vp does not let the fuel set at the bottom of a huge tank with sediment for a while until it sells off.
Old Feb 26, 2008 | 11:49 PM
blu00rdstr's Avatar
blu00rdstr
Originally Posted by Mr.Big
It's not the octane boost that is the major benefit, it does have a major plus, but... the real reason is for cooling IAT's... just like meth/alky injection...
IATs are measured before the throttle body, well before the injectors. It helps to inject both before the blower and after the intercooler, before the throttle body.
Old Feb 27, 2008 | 06:25 AM
shizon'00's Avatar
shizon'00
Shoot me a PM and we'll hook up sometime. It's kind of fun having over 1100rwhp in there.
Sean
Old Nov 12, 2008 | 11:14 PM
  #33
OAG's Avatar
OAG
Cruising
