C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
need help
Old Feb 20, 2008 | 06:59 PM
huckleberrydude's Avatar
huckleberrydude
Default need help
only running about 6lbs. with conservative tune. Bad stuff today.
I'm thinking possibly head gasket.
Cylnder:
8 196
6 190
4 192
2 191
7 170
5 150
3 170
1 165
Your help please. Thank you.
Probably a week before I can tear into it. I didn't expect this as conservative as the setup was. I'm having a really bad week.
Old Feb 20, 2008 | 08:35 PM
huckleberrydude
hey Bolas, you out there?
Sorry, I'm truly bummed out this week
Old Feb 21, 2008 | 01:51 AM
4evervette's Avatar
4evervette
can you tell me what these number are..it it a compression test figures or what ...whats the normal one ..
Old Feb 21, 2008 | 04:26 AM
big bollas's Avatar
big bollas
Just seen this bro and I am sorry to hear it.
By the numbers looks like you have lifted a head some how and you are now losing compression on the drivers side head.
Are you blowing out any kind of white smoke?
Have you checked your oil to see if it is chocolate like ?
What were the conditions when this happen ?
What type of tune do you have ? From ATI or installer?
Let me know bro and I will try and help you out in any way I can
Old Feb 21, 2008 | 09:00 AM
excessive81's Avatar
excessive81
let us know what was going on and what happened...head gasket pretty easy in the scheme of things....
Old Feb 21, 2008 | 09:22 AM
huckleberrydude
Custom tune very conservative.
20degrees outside
93 octane
oil looks fine.
didnt notice excessive smoke.
idles smooth but sounds muffled and spitting under load.
down on power obviously.
car was at operating temperature
If I pull one head then I have to do both of them and It will up the comp. ratio, correct?
Old Feb 21, 2008 | 02:07 PM
excessive81
you can do just the one head. just get another stock gasket and nothing will change. only reason it would change is if you used a thinner or thicker gasket
Old Feb 21, 2008 | 02:25 PM
huckleberrydude
it it true that when you pull the head bolts the head may not remain true, thus requiring clean up that will affect the comp. ratio?
Is it true that you must use new bolts?
Old Feb 21, 2008 | 03:08 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
it it true that when you pull the head bolts the head may not remain true, thus requiring clean up that will affect the comp. ratio? - No
Is it true that you must use new bolts? - Yes
hth
Old Feb 21, 2008 | 07:25 PM
huckleberrydude
any more info would be mucho appreciated.
To need help
